Archive 2013 · D800 10 pin connecter problem
dgardner
p.1 #1 · D800 10 pin connecter problem
My D800 10 pin connector is suddenly not working...The release itself works as in was tested with another camera. Is this something I'm going to send back to Nikon?
Thanks in advance
May 06, 2013 at 12:01 PM
runamuck
p.1 #2 · D800 10 pin connecter problem
Unless you can find a bent pin and straighten it, yes. I just looked. Pins are in the remote unit. The camera is just the receptacle. It needs to go in.
May 06, 2013 at 04:27 PM
GOVA
p.1 #3 · D800 10 pin connecter problem
I've seen people reporting this particular failure on D800, here at FM. Should be fixed under warranty.
May 07, 2013 at 02:23 PM
