We all know that an on-camera flash shot direct-on can cause red-eye. What I'm wondering is if a flash diffuser (such as the one below) used on a direct-on flash will prevent red-eye? Or no difference?
All they really do is send light in all directions the source size and placement is still the same.
Most photogs will either bounce off walls, get the flash off the camera or bleed in a good amount of ambient light topping it up with direct flash, all of which mean no red-eye. You only really get it when you are blasting on camera flash at people which isn't a great look anyway, in the days of poor high iso photogs would often use flash brackets to get the flash further off the lens axis.
TTLKurtis wrote:
It has more to do with the angle. You want the flash away from the lens a bit. That's why point n shoots have crazy red eye
I don't think it will make much difference - as TTLKurtis says, it's more about how close the flash is to the lens
- using an external flash raises the flash head away from the lens
- this is useful at short distances
If you are a long way from your subject (like 30 feet), the flash is still 'close' to the lens from their perspective, so you will still see red eye at long distances
one benefit of this type of diffuser is it does soften the harshness of direct flash a little bit, I don't think I have ever gotten a red eye when using one of these on my flash, but I have when using direct flash without the diffuser, it happened recently, though of course I was able to edit images after the fact
Putting a diffuser on your on-camera flash does not change the angle of reflection off the retina, which is the cause of red-eye. Red eye is caused by having the flash close to on-axis with the lens, which means the light reflects off the retina and straight back into the lens. It's sort of like what happens when you point your flashlight at a reflective street sign and the sign seems to reflect blinding amounts of light back at you. If your friend fifty feet away shines a light on the street sign, it doesn't produce the same highly reflective effect from your perspective.
In addition, the wider open the subjects pupils are, and the more powerful the flash is (especially compared to ambient), the more you see red-eye.
The diffuser helps a tiny bit by distributing more light out to other surrounding surfaces from which it bounces back down to the subject. This has a similar effect to increasing ambient light very slightly. But the primary light source on the subject is still usually the strobe, diffused or not,
If you want to eliminate red eye, get the primary light source away from the lens axis. This means bouncing or using off-camera flash, or at least using a flash bracket (cue '70s music).
This, the stofen does not change the size or placement of the source it just sends light in all directions that then bounces off walls/wherever and fills the shadows very slightly. I facepalm when I see people use these outside for fill.
Bounce, use it off camera, or bleed in more ambient and your problems will solved instead of buying more tupperware.
It has more to do with how close the angle of light is to the angle of the lens to the subject. Bouncing the light off a wall behind you (if that's an option), or using OCF is a much more effective kill for red-eye...
Just wanted to give a follow-up here.
A month back I snapped a bunch of shots at the reception with the flash aimed direct on [i.e. no bounce] and covered with a Stofen-like diffuser (like the one shown in my initial post in this thread). Just got a chance to peek at some of the photos in question and ....................
Yes, there was red-eye. Perhaps there was less red-eye than there would have been without the diffuser attached. Or perhaps not. Either way, there was plenty of red-eye to be found. I only looked at about twenty of the shots and red-eye seemed to affect most of them. In no way can you say this type of diffuser eliminates red-eye.
