Archive 2013 · AF dot tuning for zooms question.
RogerC11
p.1 #1 · p.1 #1 · AF dot tuning for zooms question.
I am getting 2 different values for 70mm and 200mm for my 70-200mm. Do I split the difference here? I believe it was something along the lines of -3 and +9 respectively.
May 02, 2013 at 02:12 AM
Wahoowa
p.1 #2 · p.1 #2 · AF dot tuning for zooms question.
I assume you used 5D2 or 7D?
It depends on your preference:
- average them,
- choose the focal length that you use most (long end or wide end) and stick with that number, or
- use the long end number as it's more critical with narrower DOF.
Cheers.
May 02, 2013 at 02:26 AM
