lordarka Offline Dedicated FM Upload & Sell: Off
eronald wrote:
I shoot both cameras side by side; full frame the pix look identical on a 13x18 inch, when the 1DII happens to focus correctly. The 1DII has huge speed, a bottomless buffer and no noise. However, when you need to crop and enlarge a tiny piece the 1Ds delivers while the 1DII goes soft. The 1Ds is a slow dinosaur with extremely sharp teeth, the 1DII is a quick puppy with a nip rather than a bite There's an old joke, you get what you pays for. It happens to be true too for the EOS-1 series.
I've been happy with the level of detail I get with the Mark II, but of course, you can't crop as much. I don't think it's so much a matter of getting what you pay for, but rather, a matter of two cameras for different needs.
As for the 85mm f/1.2/1D Mark II combo, I've been using it extensively, and it works very well for a lot of things. For fashion/glamour, it's a great combo as long as you can keep your cropping as close to 'in camera' as possible. I have only a little experience with the 1Ds, so I won't go to far out on a limb, but I think the combo (Mark II + 85mm) delivers a respectable level of detail if you pay close attention to your composition. As for speed, the AF is more accurate, but not faster. DavidP's suggestion of MF'ing and then AF'ing is a good one, and it really helps. I use the 85mm for stage work quite often, and I have found the AF to be quite adequate.
Arka C.
