Sports Corner Rules
Sports Corner Resource
Archive 2013 · 12U Softball
AndyD
p.1 #1 · p.1 #1 · 12U Softball
Sharing photos from last weekend game.
1. http://www.andrewkryan.net/Sports/Hillsborough-Spring-Thaw/12U-Hillsborough-Hustle-vs/i-XSDThs9/0/XL/32-XL.jpg
2. http://www.andrewkryan.net/Sports/Hillsborough-Spring-Thaw/12U-Hillsborough-Hustle-vs/i-VdRrSM3/0/XL/33-XL.jpg
3. http://www.andrewkryan.net/Sports/Hillsborough-Spring-Thaw/12U-Hillsborough-Hustle-vs/i-R4V45cv/0/XL/34-XL.jpg
4. http://www.andrewkryan.net/Sports/Hillsborough-Spring-Thaw/12U-Hillsborough-Hustle-vs/i-H7rt86q/0/XL/38-XL.jpg
5. http://www.andrewkryan.net/Sports/Hillsborough-Spring-Thaw/12U-Hillsborough-Hustle-vs/i-8fcskDK/0/XL/40-XL.jpg
6. http://www.andrewkryan.net/Sports/Hillsborough-Spring-Thaw/12U-Hillsborough-Hustle-vs/i-bGDt9n8/0/XL/42-XL.jpg
Cheers,
Andy
Apr 25, 2013 at 05:11 PM
TSpyers
p.1 #2 · p.1 #2 · 12U Softball
Andy -- Thanks for sharing! I like the action that #4 brings to the table...starting to slide, runners facial expression, who will get there first ball or runner...and for me that is the exciting part of that image.
Tim
Apr 25, 2013 at 05:49 PM
jmcaverly
p.1 #3 · p.1 #3 · 12U Softball
Nice sequences & action.
Apr 25, 2013 at 06:43 PM
AndyD
p.1 #4 · p.1 #4 · 12U Softball
Tim
Thanks Tim. I appreciate your comment.
May 01, 2013 at 12:29 PM
AndyD
p.1 #5 · p.1 #5 · 12U Softball
Thanks
May 01, 2013 at 12:31 PM
Ted ellis
p.1 #6 · p.1 #6 · 12U Softball
Of all your shots, #3 is the best representing the play. #4 is close. Well done.
May 01, 2013 at 02:01 PM
shaneroper
p.1 #7 · p.1 #7 · 12U Softball
Great shots super sharp and clean!
May 01, 2013 at 11:04 PM
Robert Carr
p.1 #8 · p.1 #8 · 12U Softball
man, they look older than U12's...
May 02, 2013 at 01:59 AM
rddayton
p.1 #9 · p.1 #9 · 12U Softball
Ted is right on the money. I'd like to add on a bit do it. As good as 1 & 2 are -- they pale in comparison to number 3. For that reason alone, I don't know that I would have included them in the set. Four is also much better than the rest in that sequence. I'm sure you are trying to tell the story of what happened on the play, but sometimes a little bit of intrigue is what makes the shot.
Rick
May 02, 2013 at 10:12 AM
Aqualung
p.1 #10 · p.1 #10 · 12U Softball
echo what Rick & Ted said...very nice. What's w/ the blue tuft sticking out of the ground on the 3B line?
Chris
May 02, 2013 at 12:46 PM
RyanL
p.1 #11 · p.1 #11 · 12U Softball
Guessing that's a marker for another base, multi use field maybe?
May 02, 2013 at 08:32 PM
rddayton
p.1 #12 · p.1 #12 · 12U Softball
Chris
Different aged kids play on fields with different length base paths. Many fields are used for a lot of different age groups, and as a result could have two or three base positions. The field crews put those blue tufted plugs in the ground to keep the dirt out of the holes not being used. When they use the field for a different age group, they simply pull the plug, drop the base into the hole and pop the plug into the other base position. Quick and easy -- and really helpful when different age groups back-to-back games on the same field. Rarely happens on high school fields -- but happens a lot in youth leagues.
Rick
May 09, 2013 at 11:49 AM
