Archive 2013 · Can FV lock only be setup as a custom function button on ...
graham_martin
p.1 #1 · p.1 #1 · Can FV lock only be setup as a custom function button on D7000?
I have an SB-800 and would like to use FV lock from time to time. As far as I can tell one can only activate this feature by assigning it to the Function button.
Is this correct?
Apr 19, 2013 at 11:04 PM
BigIronCruiser
p.1 #2 · p.1 #2 · Can FV lock only be setup as a custom function button on D7000?
FV Lock can also be assigned to the Preview button on D800's and D4's. Don't count on FV lock, by the way, if you're firing OCF's with PW's.
Apr 20, 2013 at 04:18 AM
graham_martin
p.1 #3 · p.1 #3 · Can FV lock only be setup as a custom function button on D7000?
Thanks for the added info about the preview button. From what I understand this is used in a focus-recompose situation in order to maintain the same flash output.
Apr 20, 2013 at 11:54 AM
