Depp Offline Upload & Sell: Off
First, are you using all the focus points or just one focus point?
If you select the centre point and focus on close object, then on far object, does it work?
Second, Have you done a hard reset on the camera by removing both batteries?
Third, the flexfoil may be cracking and when it finally breaks the focus will no long work...if this is the problem, time for Canon will install a new flex PCB.
What to Do When Your Lens Quits
