Archive 2013 · Acra Swiss ballhead or Adapter Plate
SamSpade1941
p.1 #1 · p.1 #1 · Acra Swiss ballhead or Adapter Plate
I am in the market for a ball head or adapter for a ball head. I really like the RRS ball heads and adapters but they are a bit out of my range new. Can anyone here recommend or share with me what they use and help me find a good solution that is somewhat economical.
Apr 14, 2013 at 04:28 AM
MazeRunner
p.1 #2 · p.1 #2 · Acra Swiss ballhead or Adapter Plate
What's your price range and how much weight?
Apr 14, 2013 at 04:49 AM
SamSpade1941
p.1 #3 · p.1 #3 · Acra Swiss ballhead or Adapter Plate
I actually want it to be able to support my Bronica Sq-Ai as well as my D200's if that helps. Unfortunately I am looking at $200 or less. I cant do more than that. As usual my hunt will probably be for anything used since the new equipment is more than I can afford .
Apr 14, 2013 at 05:01 AM
Sven Jeppesen
p.1 #4 · p.1 #4 · Acra Swiss ballhead or Adapter Plate
What do you mean by "Acra Swiss ballhead or Adapter Plate "?
Is it a ballhead with a Arca-Swiss Quick Release plate that you like to have?
Apr 14, 2013 at 06:43 AM
Gochugogi
p.1 #5 · p.1 #5 · Acra Swiss ballhead or Adapter Plate
The Sunwayfoto FB-44 is probably the cheapest nice head for two bills:
http://www.amazon.com/SUNWAYFOTO-Tripod-Compatible-FB-44-Sunway/dp/B008H715SY/ref=sr_1_8?ie=UTF8&qid=1365955756&sr=8-8&keywords=sunwayfoto+ball+head
If you can save a little longer, you can help support the USA by buying the Acratech Ultimate Ballhead. With clamp it is $290 and is one of the best for a lower price.
http://acratech.net/product.php?productid=7
If you need budget plates, the Sunwayfoto plates are hard to beat (Amazon 'n Fleabay). I use several of them and they're excellent.
However, if you already have a decent ball head, but no Arca clamp, you only need to spend $50 to $80 for a good clamp (remove disk and screw on ball stem).
Apr 14, 2013 at 04:15 PM
SamSpade1941
p.1 #6 · p.1 #6 · Acra Swiss ballhead or Adapter Plate
Thanks so much I truly appreciate all the help and advice.
Apr 15, 2013 at 06:59 PM
