Archive 2013 · Best Macro Lens? Need some suggestions...
mendo
p.1 #1 · p.1 #1 · Best Macro Lens? Need some suggestions...
Need some help picking out a lens. Looking to buy a macro lens to shoot flowers, and other objects, extremely close to create abstract compositions. Rented the Nikon 105vr last weekend but it does not work as well as I would like as I get close. The focus depth of field narrows a lot when I get close to the subject. I know Sigma and Tamron also make macro lens and that I could go up to 180mm or down to 60mm. I would appreciate some suggestions on other lenses to look at from those of you who have them.
Apr 07, 2013 at 12:06 AM
Jeffrey
p.1 #2 · p.1 #2 · Best Macro Lens? Need some suggestions...
Gear forum?
Apr 07, 2013 at 12:09 AM
Genes Home
p.1 #3 · p.1 #3 · Best Macro Lens? Need some suggestions...
You will do better with this question in the macro forum.
but since you are here......look at the Sigma 150mm macro. Built like a tank, 1-to-1 focal ratio, larger if you add extension tubes. Mine is very sharp. I find that the autofocus works very well at most ranges down to about 1.5 feet. Closer than that it's best to manually focus anyway.
Gene
Apr 07, 2013 at 04:26 AM
dsjtecserv
p.1 #4 · p.1 #4 · Best Macro Lens? Need some suggestions...
The depth of field will be extremely narrow at macro magnification, regardless of the lens. Looking for a different lens won't solve that.
Dave
Apr 07, 2013 at 05:30 AM
Scott Kroeker
p.1 #5 · p.1 #5 · Best Macro Lens? Need some suggestions...
Your problem is not gear its technique. Look up "focus stacking".
Apr 07, 2013 at 06:45 AM
killersnowman
p.1 #6 · p.1 #6 · Best Macro Lens? Need some suggestions...
Dave
thanks for writing this so i didnt have to.
Apr 07, 2013 at 02:22 PM
