Archive 2013 · FS: REDUCED HP DreamColor LP2480zx wide gamut monitor
JonCanfield
p.1 #1 · FS: REDUCED HP DreamColor LP2480zx wide gamut monitor
 Item updated in the last 24 hours Item price reduced in the last 24 hours   HP DreamColor LP2480zx wide gamut monitor
Available
Price: $700.00
Shipping instructions: Ground shipping in the US included in price
Outstanding color display covers more than Adobe RGB color space. 24" 1920x1200 resolution, IPS panel. This is a excellent display for color critical work and has the best display to print match of any display I've ever used. The only real drawback is the price - they're about $2500
Billion-color possibilities
• Enjoy support for over one billion active colors—64 times the colors supported by traditional LCDs—from the innovative 30-bit LCD panel technology
Breakthrough color control
• Achieve what you intended with unprecedented color fidelity through a tri-color LED backlight; work with deeper colors, CRT-class black, and programmable white all on a 24-inch diagonal wide-aspect screen.
Vision-to-production precision
• Customize seven color space presets for luminance, gamma, gamut, and white point; achieve completely accurate rendition of sRGB, Adobe RGB, Rec. 601, Rec.709, and DCI-P3 (97%) at the touch of a button.
Enhanced connectivity
• Get connected to all your devices with analog, DVI-I, Display Port 1.1, HDMI 1.3, component, S-video, and composite inputs, HDCP support for protected content, and an integrated USB hub.
Flexible positioning
• Be comfortable with adjustable tilt, swivel, height adjustment, and pivot rotation.
Easy-to-use OSD
• Quickly customize a range of user and color calibration settings with the completely redesigned onscreen display. New auto-fade backlit bezel buttons enable easy viewing in bright and dark work environments.
Apr 05, 2013 at 04:36 PM
JonCanfield
p.1 #2 · FS: REDUCED HP DreamColor LP2480zx wide gamut monitor
Still available
Jun 10, 2013 at 09:50 PM
mrak1979
p.1 #3 · FS: REDUCED HP DreamColor LP2480zx wide gamut monitor
I'm very interested. I have sent you an email requesting photos. Please please reply if still available.
thanks
Amos
[email protected]
Jun 22, 2013 at 08:34 PM
contrastfilms
p.1 #4 · FS: REDUCED HP DreamColor LP2480zx wide gamut monitor
Is this still available?
Jun 24, 2013 at 12:04 AM
Tom Conway
p.1 #5 · FS: REDUCED HP DreamColor LP2480zx wide gamut monitor
PM sent.
Jul 13, 2013 at 08:10 AM
