Archive 2013 · D800e firmware update problem
tkhasawinah
p.1 #1 · p.1 #1 · D800e firmware update problem
I'm having a problem updating the firmware on my D800e. Downloaded the correct file, ran the executable file and transferred the bin file to my SD card. In the menu, I click on update but when I highlight the YES it is highlighted in red rather than yellow and does not do anything when I press ok. Also tried it with a CF card with same result. Called Nikon but they couldn't figure out what was wrong.
Apr 05, 2013 at 03:10 AM
runamuck
p.1 #2 · p.1 #2 · D800e firmware update problem
Format the card in your computer. Then put the BIN file on. It needs to be in the top (root) directory to be recognized.
Apr 05, 2013 at 03:43 AM
runamuck
p.1 #3 · p.1 #3 · D800e firmware update problem
Beware, the BIN files are different for the D800 and D800E. Make sure you have the right file.
Apr 05, 2013 at 04:01 AM
PIOK
p.1 #4 · p.1 #4 · D800e firmware update problem
charge your battery
Apr 05, 2013 at 08:39 AM
mikesrc
p.1 #5 · p.1 #5 · D800e firmware update problem
I had the same problem yesterday. Walked away from the camera for a couple of hours came back worked perfect.
Apr 05, 2013 at 11:44 AM
tkhasawinah
p.1 #6 · p.1 #6 · D800e firmware update problem
I got it to work now. I put a freshly charged battery in and formatted the SD card before transferring the bin file onto it. I also pressed the "OK" button on left lower corner rather than on the joystick on right upper corner. Thanks everyone.
Apr 05, 2013 at 05:43 PM
derry1
p.1 #7 · p.1 #7 · D800e firmware update problem
I had just over a 50% charge in battery and when I tried to load the software it told me battery was to low,, inserted fresh battery and it ran fine,, download only takes a minute but guess they want no chance of low battery when doing this effort,,
Derry
Apr 07, 2013 at 04:47 PM
Alan321
p.1 #8 · p.1 #8 · D800e firmware update problem
It's like formatting a card - it wants you to press the real OK button instead of the set button or whatever other button most of us use as an OK button. That is why it was highlighted in red.
- Alan
Apr 08, 2013 at 02:19 PM
flatspin2
p.1 #9 · p.1 #9 · D800e firmware update problem
Just did D800 from A 1.00 B1.01 after A 1.00 B 1.01 and L 1.006 but no A 1.01 B 1.002 are they under 1.006
Apr 10, 2013 at 01:57 AM
runamuck
p.1 #10 · p.1 #10 · D800e firmware update problem
1.006 is the lens update. Make sure you downloaded the correct firmware for your camera. D800 Only works on DD800 and not D800E. I notice your profile shows a D300. This update will NOT work on a D300.
Make sure you format the card in the computer. This leaves only the top (root) directory. The BIN file must be in this directory.
When you download the file, double click it and it will set up 3 files on your computer. Copy only the BIN file to your card.
Apr 10, 2013 at 03:34 AM
