Archive 2013 · D7.1k Joystick/multi directional button
DavidWEGS
p.1 #1 · p.1 #1 · D7.1k Joystick/multi directional button
I am having an issue and wanted to know if anyone else sees this.
After shooting, on the occasion I want to check focus, I have my settings to go to medium magnification when I press the OK button (center of the multidirectional). That works, but when I tried to pan by holding down the edge of the multidirectional button, it stops after one move.
Is this a bug... or just my camera?
Apr 03, 2013 at 09:48 PM
trenchmonkey
p.1 #2 · p.1 #2 · D7.1k Joystick/multi directional button
I'm not seeing that on mine, David.
Apr 03, 2013 at 09:54 PM
DavidWEGS
p.1 #3 · p.1 #3 · D7.1k Joystick/multi directional button
Thanks Trench. I wondered if it might be this lens I thought I would try (Sigma 17-70)?
Just popped the nikon back on there and all is well !?
Apr 03, 2013 at 10:00 PM
DavidWEGS
p.1 #4 · p.1 #4 · D7.1k Joystick/multi directional button
Guess this is a no go then. Looked good from reviews, but my copy, while sharp in the center (very), is mushy at the edges. Even stopped down to f9+ it is not good.
Back it goes.
EDIT: reason to send it backů how F9 looks...
Apr 03, 2013 at 10:02 PM
tjny
p.1 #5 · p.1 #5 · D7.1k Joystick/multi directional button
David , for general photography and landscape nothing beats Nikon's 16-85 VR not even two zeiss primes I had. I will no exchange it, not even for Nikon' s fabulous 17-50 f 2.8.
Apr 04, 2013 at 12:07 AM
DavidWEGS
p.1 #6 · p.1 #6 · D7.1k Joystick/multi directional button
Thanks for that tjny,
I wanted the macro on this lens, but it seems to make the D7.1k funky and the IQ on the edges is awful.
Apr 04, 2013 at 04:01 PM
tjny
p.1 #7 · p.1 #7 · D7.1k Joystick/multi directional button
Nikon 16-85 vr has magnification ratio of 1:4.6 and a Killer VR.
A hand held shot here, don't like carrying tripods
http://m4.i.pbase.com/o6/37/660437/1/142360054.BGExYiyW.sm_AA72606_01.JPG
f 16 at 1 second!
Apr 05, 2013 at 02:56 AM
DavidWEGS
p.1 #8 · p.1 #8 · D7.1k Joystick/multi directional button
you should change your name tag to Steady Eddie
Apr 05, 2013 at 03:39 AM
sjms
p.1 #9 · p.1 #9 · D7.1k Joystick/multi directional button
I beg to differ I believe the sigma 17-70 f2.8-4 outshines the pack. both the newer and its previous version.
this is with the previous version which I have been using since I got my D7000:
http://www.pbase.com/crusader/image/147990926/original
http://www.pbase.com/crusader/image/147990930
http://www.pbase.com/crusader/image/146896488
http://www.pbase.com/crusader/image/146916887
http://www.pbase.com/crusader/image/146896614
http://www.pbase.com/crusader/image/143872578
close up images
http://www.pbase.com/crusader/image/143123649
http://www.pbase.com/crusader/image/148275175
http://www.pbase.com/crusader/image/145443393
Apr 05, 2013 at 01:33 PM
trenchmonkey
p.1 #10 · p.1 #10 · D7.1k Joystick/multi directional button
Over Sat might be more appropriate
Apr 05, 2013 at 01:51 PM
billsnature
p.1 #11 · p.1 #11 · D7.1k Joystick/multi directional button
My Results very similar to Davids. I aslo tested the Tamron 17-50mm F2.8 VR and got very similar results. The 17-70 was sharper in center, but much in corners, The 17-50 was OK in center and marginal in corners.
I wound up deciding to use Nikon 18-35G and 24-84VR as a combo. They are light and very sharp out to the corners on D7100 both being FX lenses
Apr 07, 2013 at 04:27 AM
