Archive 2013 · Does anyone use filters anymore?
pdt0102
p.1 #1 · p.1 #1 · Does anyone use filters anymore?
Just wondering if anyone is still carrying GND/Color filters and using it? Or prefer to do all of this in post processing.
Apr 01, 2013 at 10:54 PM
Sunny Sra
p.1 #2 · p.1 #2 · Does anyone use filters anymore?
+1 to carrying and using GND/ND filters
Apr 01, 2013 at 10:59 PM
Guari
p.1 #3 · p.1 #3 · Does anyone use filters anymore?
I carry and use filters too...
Apr 01, 2013 at 11:03 PM
Genes Home
p.1 #4 · p.1 #4 · Does anyone use filters anymore?
Yes.
I carry a set of ND (2,3,5 stop) and GND (2,3,5) 4x6 filters with a Lee mount. I have a set of step down rings to fit the mount to the four lenses that I normally use.
I also have a 77mm Nikon polarizer that is an essential part of my kit. If there's water, the filter normally gets used.
I have considered one of the variable ND filters, but they are awful expensive given that I already have a pretty good set of gear.
Gene
Apr 01, 2013 at 11:29 PM
johnnygator
p.1 #5 · p.1 #5 · Does anyone use filters anymore?
For digital I carry 77mm Circ Polarizer, 3 & 10 stop ND, Singh Ray IR, Gold N Blue & P sized GND filter.
For B&W 4x5 I carry 77mm red & green filters.
If I can capture the look I'm going for in camera, I prefer to do so.
Apr 01, 2013 at 11:48 PM
Micky Bill
p.1 #6 · p.1 #6 · Does anyone use filters anymore?
I have a variable ND (I use for video too) a regular ND and a couple polarizers, thinking of getting a GND or two....but not seriously.
Edited on Apr 02, 2013 at 05:55 PM · View previous versions
Apr 01, 2013 at 11:52 PM
camboman
p.1 #7 · p.1 #7 · Does anyone use filters anymore?
Same as most of the above - I occasionally use a polarizer, but mostly use ND filters to slow down motion.
Apr 02, 2013 at 12:00 AM
abbyedahl
p.1 #8 · p.1 #8 · Does anyone use filters anymore?
i'm a big fan of GND's. The lee big stopper (or other 10 stop filters) also create some great effects you can't create in post.
Apr 02, 2013 at 06:20 AM
pink
p.1 #9 · p.1 #9 · Does anyone use filters anymore?
Personally (from experience) I would avoid the variable ND filters, hard to get a consistent effect over the whole frame, may work ok on non-wide lenses, I sold mine and stick to my Lee big stopper, also use hard and soft grads.
ian
Apr 02, 2013 at 06:26 AM
Phrasikleia
p.1 #10 · p.1 #10 · Does anyone use filters anymore?
No, I don't carry my GNDs anymore. CPLs and NDs, but not the grads. I prefer blending now.
Apr 02, 2013 at 07:45 AM
RobDickinson
p.1 #11 · p.1 #11 · Does anyone use filters anymore?
We had a chat about this a few months ago.
I still use filters, grads, nd, polariser, along with digital techniques. Nothing is appropriate in every situation.
Apr 02, 2013 at 08:02 AM
vin14
p.1 #12 · p.1 #12 · Does anyone use filters anymore?
Not as much as I used to, mostly just a ND for water these days. I used to used ND grads a lot more because of less DR in my older (pre 2005) DSLRs, was never a polariser fan
Apr 02, 2013 at 12:14 PM
gdanmitchell
p.1 #13 · p.1 #13 · Does anyone use filters anymore?
Never carry color filters - I have more power in post over the things for which I used them in the past.
Never cary GND filters - I have much more power via exposure blending.
Do carry circular polarizers and neutral density filters since both accomplish things that cannot be done in post.
Do search out some of the old threads on this topic since there has been quite a bit of discussion of this in the past, particularly the question of relative advantages/disadvantages of GND filters in the era of digital photography.
Apr 02, 2013 at 01:58 PM
nburwell
p.1 #14 · p.1 #14 · Does anyone use filters anymore?
My CPL and ND filters get used regularly. However, my GND filters, more often than not, simply sit in my bag. In that case, I probably will correct anything in post processing. However, I really should start utilizing my GND filters more.
-Nick
Apr 02, 2013 at 04:04 PM
kylebarendrick
p.1 #15 · p.1 #15 · Does anyone use filters anymore?
I general keep circular polarizers on my lenses.
I still use a 2-stop, soft-edge GND - usually handheld. I have no problem blending exposures, but if I can capture everything in one frame then I am less likely to screw something up on my computer.
Apr 02, 2013 at 04:05 PM
Guari
p.1 #16 · p.1 #16 · Does anyone use filters anymore?
Does anyone have a link to exposure blending tutorial for landscapers?
I still use filters and love it, but I truly would like to learn about exposure blending it. I can not seem to be able to do it properly, I will get weird luminance do to a poor selection and stuff... I would really like to see how those that shoot filterless do it..
And I've tried HDR but was never a fan of the haloing..
Apr 02, 2013 at 04:30 PM
dakel
p.1 #17 · p.1 #17 · Does anyone use filters anymore?
GND - not any more
Polariser - Yes but don't use very often
ND - Yes, for long exposures
Apr 02, 2013 at 07:22 PM
Mark Metternich
p.1 #18 · p.1 #18 · Does anyone use filters anymore?
I have not used a color filter ever.
Been 6 years since I used a ND grad, except for super long exposures in a high dynamic range situation.
Still always use a polarizer around water.
Apr 03, 2013 at 12:20 AM
StarNut
p.1 #19 · p.1 #19 · Does anyone use filters anymore?
I carry one graduated ND (2 stop, I think).
I carry two ND filters (2 stop and 6 stop), since these allow me to do things (e.g., long exposure of rushing water in bright light) I can't do merely with PP.
And I carry a circular polarizing filter, for the same reason.
YMMV
Mark
Apr 03, 2013 at 12:56 AM
Scott Kroeker
p.1 #20 · p.1 #20 · Does anyone use filters anymore?
When ever I can I use filters!
Some of my most evocative photos are close to straight out of the camera using filters.
Apr 03, 2013 at 01:22 AM
