Rules & Guidelines | PayPal Gift Warning
Archive 2013 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
yellow05gt
p.1 #1 · p.1 #1 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
 Item updated in the last 24 hours Item price reduced in the last 24 hours   Manfrotto 3001BPRO
Item Sold
Price: $0.01
Shipping instructions: Free USPS Shipping
***SOLD***
Item has some marks from normal use as I used it regularly. I tried to picture them as much as possible. But there may be a few tiny others I couldn't find. I'm only selling this set up to accommodate a bigger lens purchase with a gimbal set-up. I will entertain separating everything so shoot me a PM with an offer if you're interested. I'm marking all these 8+ only because they are used and I like to under rate things. I'd rather you be pleasantly surprised than mad I didn't disclose something
Manufacturer Description
Manfrotto has taken the 3001BPRO tripod and made it even more versatile! The main refinement to this series is with the center column. Designed as an alternative to the low-angle adapter, the center column enables the head to be left mounted to the column when switching between low angle and normal shooting. The top section is detached without tools by simply unscrewing the knob at the bottom of the column.
As with the previous series, the 3001BPRO has a removable center column that doubles as a horizontal lateral arm. Not only does this allow the camera to be offset from leg position, but it provides the simplest way possible to shoot from directly overhead.
In addition, the 3001BPRO also comes with leg warmers on two legs which helps keep hands protected in cold weather and protects the body when carrying the tripod on shoulders.
Key features include:
Center column design allows you to leave the head mounted on the column when switching between low angle and normal shooting.
Leg warmers on two legs which keeps hands protected in cold weather and protects the body when carrying the tripod on shoulders.
Double positioning vertical and horizontal center column.
Rapid-action lever leg locks with just 45-degree run.
Four leg-angle settings.
Product Description
Mounts on any column 3/8 thread, this side arm allows positioning of two heads on a 90deg. perpendicular angle.
Maximum Height 57.0" (144.8 cm)
Maximum Height w/o Column Extended 46.7" (118.6 cm)
Minimum Height 8.2" (20.8 cm)
Folded Length 22.0" (55.9 cm)
Load Capacity 11.00 lb (4.99 kg)
Leg Sections 3
Leg Lock Type Flip levers
Independent Leg Spread Yes
Center Column Sections 1
Center Column Type Rapid
Head Type None
Head Mount Thread Size 3/8"-16
Weight 4.20 lb (1.91 kg)
 Item updated in the last 24 hours Item price reduced in the last 24 hours   Manfrotto 494RC2
Item Sold
Price: $0.01
***SOLD***
I couldn't really find any marks on this one, but I'm sure there are a few as I used it regularly. Still functions great! Would possibly put towards the trade of a RRS BH-55 or the likes. I will entertain separating everything so shoot me a PM with an offer if you're interested. I'm marking all these 8+ only because they are used and I like to under rate things. I'd rather you be pleasantly surprised than mad I didn't disclose something
The Manfrotto 494 Mini Ball Head w/RC2 QR Plate is a lightweight ball head that's perfect for smaller cameras (maximum load--8.82 lbs). It's got a quick-release plate, a newly designed friction control knob that allows micro movements without engaging the head-locking mechanism, and a locking mechanism that will lock the head in both the +90/-90 tilt position and the 360 panning position.
A new friction control knob allows micro movements without having to engage the head locking mechanism
A smart ratcheting locking lever allows the user to place it in a comfortable position in order to use it in the most convenient way
The locking lever securely locks the head both in the +90 and -90 ball positions and in the 360 pan movements
 Item updated in the last 24 hours Item price reduced in the last 24 hours   Manfrotto 676B Monopod
Item Sold
Price: $35.00
***Price is $35 shipped and paypald OBO***
I didn't really use this as much as I thought I would, so I'm including it in the sale. I will entertain separating everything so shoot me a PM with an offer if you're interested. I'm marking all these 8+ only because they are used and I like to under rate things. I'd rather you be pleasantly surprised than mad I didn't disclose something
A simple, easy to set up monopod. The four section leg design allows it to fold up to less than 20", and weighs less than a pound. Features rapid-action flip locks for the leg extensions, strap, and a 1/4-20" screw
Maximum Height 60.6" (154 cm)
Folded Length 18.9" (48 cm)
Load Capacity 10 lb (4.5 kg)
Sections 4
Male Thread Size 1/4-20"
Weight 14.1 oz (400 g)
Edited on Apr 22, 2013 at 04:45 PM · View previous versions
Apr 01, 2013 at 12:10 AM
1KIND
p.1 #2 · p.1 #2 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
I'll take it all for $1 each!
Apr 01, 2013 at 03:14 AM
yellow05gt
p.1 #3 · p.1 #3 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
haha I'm sure everyone here would. The price for the whole kit is in the title...$175 shipped and paypal'd
Apr 01, 2013 at 03:48 AM
1KIND
p.1 #4 · p.1 #4 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
FYI, its best if you put price in description or the actual price instead of $1. The title can be overlooked quickly considering it doesn't show it and it's only visible in 1 spot and is fairly hard to see.
Apr 01, 2013 at 11:28 AM
yellow05gt
p.1 #5 · p.1 #5 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
Thanks I appreciate it. I'll change it up to where the price is in each description.
Apr 01, 2013 at 04:11 PM
MAYBEN
p.1 #6 · p.1 #6 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
PM sent
Apr 02, 2013 at 05:50 PM
08kecarv
p.1 #7 · p.1 #7 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
If you decide to split it up iʻm interested in the monopod
Apr 04, 2013 at 08:29 AM
yellow05gt
p.1 #8 · p.1 #8 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
PMd
Apr 04, 2013 at 02:48 PM
estrellas321
p.1 #9 · p.1 #9 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
If you decide to split it up iʻm interested in the ball head
Apr 05, 2013 at 02:51 PM
yellow05gt
p.1 #10 · p.1 #10 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
PM sent
Apr 05, 2013 at 07:03 PM
rewart
p.1 #11 · p.1 #11 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
PM sent for legs
Apr 12, 2013 at 04:15 AM
yellow05gt
p.1 #12 · p.1 #12 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
rewart wrote:
PM sent for legs
PMd back
Apr 12, 2013 at 04:25 AM
yellow05gt
p.1 #13 · p.1 #13 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
Tripod, ballhead, and QR plates are SOLD
Monopod still available: $40 shipped and paypal'd.
Apr 13, 2013 at 02:59 AM
echoxgxg
p.1 #14 · p.1 #14 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
tag
Apr 19, 2013 at 07:56 PM
yellow05gt
p.1 #15 · p.1 #15 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
Price Drop $35 PayPal'd and shipped
Apr 20, 2013 at 02:28 AM
vobraman
p.1 #16 · p.1 #16 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
Pm sent.
Apr 22, 2013 at 04:39 AM
vobraman
p.1 #17 · p.1 #17 · Sold: Manfrotto 676B Monopod $40 shipped/Paypal'd
Payment sent
Apr 22, 2013 at 04:31 PM
