Archive 2013 · The strange disappearance (and miraculous discovery) of i...
verbiage
p.1 #1 · p.1 #1 · The strange disappearance (and miraculous discovery) of images in 5D III
Just an observation:
I was testing (aka fooling around with) a new 5D Mark III, and put in a couple of cards I'd used on other cameras - there was still a fair amount of free space left on each, and I needed a few old files off the CF. so I decided against formatting the cards: a new user, I was not sure I wouldn't format the wrong card by accident.
Act 1.
I tried a few different settings for saving images to both or one card, and kept on shooting after picking "sequential, automatic switch between cards" (not sure if these are the exact words in the menu, but that's the idea), and just kept shooting. I did a bit of chimping, and all was well.
Act 2
After putting the cards into my computer (an "ancienescent" desktop with all manner of card slots, thank you, HP!), I couldn't find most of the files I took with the new 5D - I looked in the root directory of each card, the DCIM/100CANON folder, they were very simply not there. I started getting ideas - bad card? was there an option the opposite of "shoot without card" (something like "shoot but don't save")? Did I dream the whole thing? I decided to transfer files to HDD before checking again in the camera.
Act 3
I had stuck the SD card into a Panasonic mFT body I tried out at a store a few days previously, so the card had a 104_PANA folder on it. I decided to take a look in there, just in case, and lo and behold, the latest 5D III images were all in it!
Interesting that the 5D III chose to save them there rather than to an older 100CANON directory created by a 60D.
Off to format the cards now.
A good Sunday to all!
S.K.
p.s edited for clarity
Edited on Apr 01, 2013 at 01:05 AM · View previous versions
Mar 31, 2013 at 10:58 AM
AGeoJO
p.1 #2 · p.1 #2 · The strange disappearance (and miraculous discovery) of images in 5D III
verbiage wrote:
Act 2
After putting the cards into my computer (an "ancienescent" desktop with all manner of card slots, thank you, HP!), I couldn't find most of the files I took with the new 5D - I looked in the root directory of each card, the DCIM/100CANON folder, they were very simply not there. I started getting ideas - bad card? was there an option opposite to "shoot without card" (something like "shoot but don't save")? Did I dream the whole thing? I decided to transfer files to HDD before checking again in the camera.
Act 3
If you go to the first button of the yellow menu "Record func+card/folder sel.', the second menu in there lets you select the storage card. In other words, you can choose to record/play either the CF card or SD, regardless of the folder name or created by what camera.
Mar 31, 2013 at 03:47 PM
Sarsfield
p.1 #3 · p.1 #3 · The strange disappearance (and miraculous discovery) of images in 5D III
But he's right. It should have defaulted to a Canon created folder from the previous camera model. Definitely a glitch unless you have the option of "where' to save on a specific card with the 3. I don't know. I own a 2.
Mar 31, 2013 at 05:47 PM
scalesusa
p.1 #4 · p.1 #4 · The strange disappearance (and miraculous discovery) of images in 5D III
You can set the folder. Since he did not set it up, it probably took the first one it came to.
It likely changed to the SD card, if you remove the CF card, it will select the SD card and remain there.
Apr 02, 2013 at 01:56 AM
EB-1
p.1 #5 · p.1 #5 · The strange disappearance (and miraculous discovery) of images in 5D III
The folder should not matter if you use a proper downloading app. Format the card in the computer if you want it to be clean.
Apr 02, 2013 at 02:20 AM
verbiage
p.1 #6 · p.1 #6 · The strange disappearance (and miraculous discovery) of images in 5D III
Thank you for your comments and tips - yes, I know I should get to know my camera a bit better and be more comfortable knowing at any point in time where it is writing images.
Eric, I am pretty old school where image transfer is concerned - I like going into the folder on the memory card, picking what I want and copying them where I want them. Not the most efficient way, but it works if you don't want any surprises
All the best,
S.K.
Apr 02, 2013 at 06:52 AM
