Archive 2013 · Shortcut to process all variants in Capture 1 Pro 7?
pjny
p.1 #1 · p.1 #1 · Shortcut to process all variants in Capture 1 Pro 7?
Hi,
What is the difference between Export (Variants) and Process variants? I basically want to export (to JPG) a set of selected images from a catalog.
If I use my shortcut( ' key to process) to process a bunch of selected images --- only the first images selected is exported to a jpeg. (only the primary variant)
I don't want to have to hit the process key in the Process Recipes toolbar. I just want to be able to hit ' key and process selected images. How do I do this?
The only way I can get all images to be processed is "file..export...variants..." Tedious.
Mar 31, 2013 at 06:31 AM
Snead
p.1 #2 · p.1 #2 · Shortcut to process all variants in Capture 1 Pro 7?
You might try posting your question here;
http://forum.phaseone.com/En/viewforum.php?f=47
CO7 support people often answer questions there. As far as I'm concerned it's the only decent CO7 support available.
Mar 31, 2013 at 11:47 AM
mshi
p.1 #3 · p.1 #3 · Shortcut to process all variants in Capture 1 Pro 7?
pjny wrote:
Hi,
Select those needing export by either control-click or alt-click first. Then click on Output Tab, select your desired Process Recipes, and SHIFT-Click the Process under Process Summary.
Mar 31, 2013 at 04:18 PM
pjny
p.1 #4 · p.1 #4 · Shortcut to process all variants in Capture 1 Pro 7?
In LR I can select a bunch of images and hit export keyboard command and all are exported.
im looking to do the same without switching tabs. is this possible?
Apr 01, 2013 at 05:49 AM
mshi
p.1 #5 · p.1 #5 · Shortcut to process all variants in Capture 1 Pro 7?
Just add Process tools to your current tab by Add Tool so you don't need to switch tabs.
Apr 01, 2013 at 05:08 PM
