Archive 2013 · Printer Setting partially crop
Tink
p.1 #1 · p.1 #1 · Printer Setting partially crop
For some reason or another when I try to print my printer setting is crop. I have tried different screen resolutions, re-installing printer software the latest version of my printer drivers ( Epson R2400) still the crop version of my printer setting. here is a screen shot of it.
I can't get to the advance tab for color management.
Mar 28, 2013 at 09:12 PM
Tink
p.1 #2 · p.1 #2 · Printer Setting partially crop
Has anyone had this happen before? I don't know what going on.
Mar 29, 2013 at 12:35 AM
Eyeball
p.1 #3 · p.1 #3 · Printer Setting partially crop
This is a guess:
Check to see if you have enlarged the standard text display size.
In Windows 7, this is in the Display control panel. See if you have set it to something larger to 100%.
If you change it, you will need to re-start or log-off/on for the text size change to take effect.
Mar 29, 2013 at 12:49 AM
Tink
p.1 #4 · p.1 #4 · Printer Setting partially crop
display is set at 100%. Using Windows 8.
Thanks for your consideration.
Mar 29, 2013 at 12:57 AM
Sunny Sra
p.1 #5 · p.1 #5 · Printer Setting partially crop
download updated software and reinstall. i have had that happen when i've done an upgrade or installed older version of the Epson 3800 printer.
Mar 29, 2013 at 01:27 AM
cwebster
p.1 #6 · p.1 #6 · Printer Setting partially crop
Is this a small screen netbook? What is your screen resolution set to?
I've seen this as an issue when installing photo software on netbooks that don't have adequate resolution to begin with.
<Chas>
Mar 30, 2013 at 12:24 AM
Sarsfield
p.1 #7 · p.1 #7 · Printer Setting partially crop
This is a "stretch" but see if you can grab the right side or lower right corner of the box to expand it. If not, right click on the box and see if there is a menu for the box. If not, left click the upper left corner and see if there's an applicable menu item there. Very weird.
Mar 30, 2013 at 12:59 AM
lesaus
p.1 #8 · p.1 #8 · Printer Setting partially crop
Have you tried checking the "Borderless" box? Just a thought.
Apr 03, 2013 at 01:14 PM
niktnowy
p.1 #9 · p.1 #9 · Printer Setting partially crop
It might be the program you are printing from. Try to check print. format settings or try to print from different applications.
Apr 05, 2013 at 01:36 AM
