Archive 2013 · 430 II flash head blown
deepbluejh
p.1 #1 · p.1 #1 · 430 II flash head blown
I was setting up for a portrait session today when the flash head on my 430II blew. It was on a Yongnuo ETTL trigger on top a light stand and had a fresh set of eneloops in it.
I wasn't firing the flash or testing it at all. It was just sitting there when I heard a loud pop. I went over to the flash, noticed the smell of smoke, and immediately turned it off. When I removed the batteries, they were hot to the touch, but nothing else seemed to be amiss. The flash would actually turn back on, but the head would not charge. The indicator light stayed off and would not show green or red.
After I got home tonight I tested the batteries and all seemed to be putting out normal "fully charged" voltage. There was nothing to indicate they had overcharged.
Any idea what happened here? Any idea what Canon will charge me to fix the flash?
Mar 24, 2013 at 11:33 PM
scottam10
p.1 #2 · p.1 #2 · 430 II flash head blown
That's unusual, especially considering you weren't actually firing the flash at the time, from your description it sounds like you hadn't been firing the flash rapidly in the lead-up to failure.
It's odd that the batteries were hot, that indicates high current through the batteries, perhaps there was a short-circuit within the flash (either before or after failure).
A flash failure can be caused by a high trigger voltage, but you weren't actually triggering the flash at the time (I assume you've used the Yongnuo triggers before without issue)
I expect that repair may be uneconomical, but you can always ask
Sorry I can't be more help
Mar 24, 2013 at 11:51 PM
deepbluejh
p.1 #3 · p.1 #3 · 430 II flash head blown
The triggers have been used many times before with no issues. It could have been a short circuit of some sort, but there was no debris or moisture inside the battery compartment. Maybe the flash malfunctioned internally?
Mar 24, 2013 at 11:54 PM
Jefferson
p.1 #4 · p.1 #4 · 430 II flash head blown
Once the smoke escapes...it's all over...most of that smoke is, (was), stored in the charging circuit...
Mar 25, 2013 at 12:02 AM
Dawei Ye
p.1 #5 · p.1 #5 · 430 II flash head blown
For me, Canon replaced the entire Auto Reflector Array for about the cost of a "level 2" labour + parts
All up approximately 2X the cost of a Sensor Clean
http://www.clartephoto.com/img/s10/v2/p137406564-4.jpg
Mar 25, 2013 at 12:35 AM
CanonPhotog
p.1 #6 · p.1 #6 · 430 II flash head blown
Sounds like a failed capacitor in the unit. If the capacitor becomes internally shorted, the batteries will continue to try to charge it and will get hot.
Mar 25, 2013 at 12:43 AM
scottam10
p.1 #7 · p.1 #7 · 430 II flash head blown
That sounds logical, I like that explanation
Mar 25, 2013 at 01:13 AM
deepbluejh
p.1 #8 · p.1 #8 · 430 II flash head blown
Just as an update on this, it turned out to be a corroded power supply... weird. Canon charged me a standard out of warranty labor ($89), plus shipping. With a CPS gold discount, it came to $62.30.
Apr 03, 2013 at 05:54 PM
BrianO
p.1 #9 · p.1 #9 · 430 II flash head blown
Well, $62.30 isn't too painful-sounding; much better than having to buy another 430 either new or used.
Any idea what would/could have caused this corrosion?
Apr 04, 2013 at 08:54 PM
deepbluejh
p.1 #10 · p.1 #10 · 430 II flash head blown
No idea... I bought the flash used so there is really no telling what caused it.
Apr 04, 2013 at 09:56 PM
faucets xp
p.1 #11 · p.1 #11 · 430 II flash head blown
Just not like spending money on Canon.
But honestly speaking, they are good quality ones.
Apr 05, 2013 at 02:25 AM
