Archive 2013 · Sold: NEC LT260 + case + spare lamp
bhusick
p.1 #1 · p.1 #1 · Sold: NEC LT260 + case + spare lamp
 Item updated in the last 24 hours Item price reduced in the last 24 hours   NEC LT260 DLP Projector
Item Sold
Price: $799.00
Shipping instructions: Fedex ground
Original owner (non-smoker, no pets) selling pristine condition NEC LT260 DLP projector with 1,024 x 768 XGA resolution with Texas Instruments DLP technology, 2,400 ANSI lumens of brightness, 30 to 500-inch display size, Extraordinary 1,600:1 contrast ratio, Keystone correction with 3-D Reform geometric correction, VORTEX Technology Plus improves white level and color accuracy.
Total of 34 hours on lamp That means I have used 1.7% of the lamp's expected life.
I will also include brand new second bulb (NEC original) valued at $300 for free. NEC custom nylon carrying case also included for free.
I will also include a new NEC rolling hard case specifically made for this projector and its accessories. $260 value, now free with the projector.
Cost more than $2700. Reviewed as 5 stars in many places.
Selling here for $799 with soft and hard cases, wireless remote with built-in laser pointer.
WILL CONSIDER TRADES FOR MINT LEICA or NIKON LENSES OF SIMILAR VALUE, or iPad Mini 64GB + Verizon model plus cash.
Works and looks just like new. No scratches, marks or blemishes.
Guaranteed no DOA.
Please check my 100% positive feedback. I have never had an unhappy transaction!
Full specs:
General
Device Type DLP projector
Built-in Devices Speaker
Width 10.2 in
Depth 11.8 in
Height 4.7 in
Weight 6.4 lbs
Projector / Panel
Image Brightness 2400 ANSI lumens
Image Contrast Ratio 1600:1
Image Size 29.9 in - 500 in
Projection Distance 4 ft - 81 ft
Resolution XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Color Support 16.7 million colors
Max Sync Rate (V x H) 120 Hz x 100 kHz
Lamp Type NSH 220 Watt
Lamp Life Cycle 2000 hour(s)
Features Eco-Mode technology, Advanced AccuBlend technology, VORTEX Technology Plus, 3D Reform technology
Projector Lens System
Lens Aperture F/2.2-2.5
Keystone Correction Direction Horizontal, vertical
Vertical Keystone Correction -40 / +40
Horizontal Keystone Correction -30 / +35
Video Input
Analog Video Format NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
Analog Video Signal RGB, S-Video, composite video
Digital Video Format HDTV
Video Output
Audio Output
Type Speaker(s) - integrated
Sound Output Mode Mono
Output Power / Channel 1 Watt
Speaker(s) 1 x mixed channel
Input Device
Type Remote control - external - wireless
Expansion / Connectivity
Expansion Slot(s) 1 x PC Card - type II
Interfaces 1 x VGA output - 15 pin HD D-Sub (HD-15) 1 x audio line-out - mini-phone stereo 3.5 mm 2 x VGA input - 15 pin HD D-Sub (HD-15) 1 x composite video input - RCA 1 x S-video input - 4 pin mini-DIN 1 x audio line-in - RCA x 2 Audio line-in - mini-phone stereo 3.5 mm 1 x USB - 4 pin USB Type B ( management ) 1 x USB - 4 pin USB Type A 1 x remote control - 8 pin mini-DIN
Miscellaneous
Included Accessories Carrying case, lens cover
Cables Included 1 x display cable 2 x USB cable
Power
Power Device Power supply - internal
Voltage Required AC 120/230 V ( 50/60 Hz )
Power Consumption Operational 280 Watt
Software / System Requirements
Software Included Drivers & Utilities
Environmental Parameters
Sound Emission 32 dB
Min Operating Temperature 32 F
Max Operating Temperature 95 F
Mar 12, 2013 at 05:39 AM
