cabin under the oaks
jrrhodes
p.1 #1 · cabin under the oaks
One of my favorite places. C/C welcome.
J.R.
Mar 03, 2013 at 12:14 AM
Dougo
p.1 #2 · cabin under the oaks
That is an amazing tree, I think it could do with a slight mid tone hit to up the contrast a bit INHOO
Cheers Ray
Mar 03, 2013 at 08:53 AM
jrrhodes
p.1 #3 · cabin under the oaks
Cheers Ray
Thanks Ray. There are several trees around that place just like that. I'll try the midtone suggestion.
J.R.
Mar 03, 2013 at 12:35 PM
GFountain
p.1 #4 · cabin under the oaks
I like the image though I'd like to see more of the cabin.
Greg
Mar 03, 2013 at 12:47 PM
p.1 #5 · cabin under the oaks
I'll side with Greg on the desire to see more of the cabin, that said, I would like to see another angle of the tree, possibly wider, without the cabin in view.
Mar 03, 2013 at 02:15 PM
jrrhodes
p.1 #6 · cabin under the oaks
Greg
Thanks Greg. I want to go back when the weather is right and try to get some alternate angles.
J.R.
Mar 05, 2013 at 12:54 AM
jrrhodes
p.1 #7 · cabin under the oaks
I might have to rent a really wide lens for that one! 35mm is as wide as I have right now. I think a 24 might work though.
J.R.
Mar 05, 2013 at 12:56 AM
Charlie Shugart
p.1 #8 · cabin under the oaks
A terrific image, J.R.
I also would like a bit more contrast.
While you're at it- rent a REALLY wide lens and get the full scope of those magnificent branches. That IS quite a tree.
Charlie
Mar 05, 2013 at 11:38 PM
iweiner
p.1 #9 · cabin under the oaks
No need to buy or rent a wider lens---doing so may capture your FOV but then the curved distortion of the many lines will be a PITA.
I suggest a reshoot with your 35 or longer lens--create an array (~ 3x3) of images covering your desired FOV and stitch them with Microsoft ICE (free). Crop the final result to suit, do note that this resulting image will contain many Megapix.--allowing tack sharp prints of considerable size. 17x25 ln and up!!!
good luck irv weiner
Mar 09, 2013 at 02:14 AM
Oosty
p.1 #10 · cabin under the oaks
JR - this is a good image that just begs for a bigger screen. I like the pp technique a lot.
Peter
Mar 13, 2013 at 08:45 PM
jrrhodes
p.1 #11 · cabin under the oaks
Peter
Thanks very much. The PP was a mix of silver e-fex pro and photoshop. I did a fairly big print, and I like this image more printed.
J.R.
Mar 14, 2013 at 01:01 AM
