Archive 2013 · 600EX-RT Question
ZWhitford
p.1 #1 · p.1 #1 · 600EX-RT Question
Hi all,
I have to shoot an event in a little over a week and it will be my first gig since switching to Canon where I will need to use a flash. I had been planning to rent the 600 but read that Canon's TTL cable is not compatible with the RT system without some kind of added component. I was wondering, what are the extra components I need to make the 600EX-RT work with Canon TTL cable?
To be safe I think for the time being I'll just rent the 580EX II and worry about getting the 600 working as I need it to for when I actually purchase the 600 to have in my kit.
Thanks very much!
Feb 26, 2013 at 01:33 AM
vivisha
p.1 #2 · p.1 #2 · 600EX-RT Question
I think you are confusing the compatibility issue. I think you're talking about the OC-E3 off camera flash shoe cord, if so, that is basically an extension cord for the flash, the terminals are exactly the same. The compatiblility issue comes when you're using a camera body that is not the 1DX, 5Dlll or 6D. But is not really a compatibility issue but a fastest sync speed one.
If you're only using TTL flash, the extension cord will work with the 600ex-rt and 500exll.
Feb 26, 2013 at 02:29 AM
ZWhitford
p.1 #3 · p.1 #3 · 600EX-RT Question
Thanks for the input.
And yes, I was referring to the OC-E3 cord. I will be shooting it manually and in TTL mode with a 5DIII so it looks like I will be ok.
Thanks again.
Feb 26, 2013 at 11:44 PM
