Archive 2013 · Canon Ultra Wides with Fluorite lens element
Admin
p.1 #1 · Canon Ultra Wides with Fluorite lens element
Canon designing ultra wides with fluorite lens element
We may be seeing Canon ultra wide angle lenses with fluorite lens element in the near future.
Canon has just released a 14mm f/2.8 Fluorite optical formula patent. This could be used in a future 14mm prime, 14-24mm or 16-35mm zooms.
For more details on this Canon patent, check out the english translated Egami's blog.
Feb 25, 2013 at 02:18 PM
a.RodriguezPix
[X]
p.1 #2 · Canon Ultra Wides with Fluorite lens element
I wonder how close up to subject these will be able to achieve?
Feb 25, 2013 at 02:28 PM
PetKal
p.1 #3 · Canon Ultra Wides with Fluorite lens element
Thank you, Fred, the writing has been on the wall for that one.
Naturally, as we all know it full well, fluorite elements are extremely expensive, and it should come as no surprise that the projected price of 16-35L MkIII, containing one fluorite element, is in the vicinity of $3,800. However, the lens will generate an increase in microcontrast in extreme corners, a feature which your clients will appreciate immensely.
Edited on Feb 25, 2013 at 02:53 PM · View previous versions
Feb 25, 2013 at 02:34 PM
Ian.Dobinson
p.1 #4 · Canon Ultra Wides with Fluorite lens element
Will they need to be white ?
Feb 25, 2013 at 02:37 PM
RobDickinson
p.1 #5 · Canon Ultra Wides with Fluorite lens element
I look forward to the new white 14mmf2.8L at $4499.
Feb 25, 2013 at 02:41 PM
AGeoJO
p.1 #6 · Canon Ultra Wides with Fluorite lens element
The problem is, it may take a few years for this design to be put in production, if any. BTW, that applies to both companies, Canon and Nikon.
Feb 25, 2013 at 02:47 PM
StillFingerz
p.1 #7 · Canon Ultra Wides with Fluorite lens element
More white bodies with green rings...interesting...black with green rings would be acceptable as well I suppose
Just have to figure out how me wallet could handle it
Feb 25, 2013 at 02:55 PM
RobDickinson
p.1 #8 · Canon Ultra Wides with Fluorite lens element
Green is for DO isnt it?
Feb 25, 2013 at 02:58 PM
StillFingerz
p.1 #9 · Canon Ultra Wides with Fluorite lens element
Thought the 400 DO was the only lens to use Fluorite, prob need to do my homework, may have mis-thought, when I hear Fluorite the 400 DO and it's green stripe jumps to mind
Feb 25, 2013 at 03:04 PM
RobDickinson
p.1 #10 · Canon Ultra Wides with Fluorite lens element
Flourite is used in the 70-200's, 100-400 and superteles.
Feb 25, 2013 at 03:11 PM
PetKal
p.1 #11 · Canon Ultra Wides with Fluorite lens element
Jerry, perhaps the green ring colour made you think of flouride tooth paste.
I think 50-200L was the first small EF lens which contained a fluorite element.
800L is the first EF lens which contains two fluorite elements.
Edited on Feb 26, 2013 at 07:36 AM · View previous versions
Feb 25, 2013 at 03:20 PM
mpmendenhall
p.1 #12 · Canon Ultra Wides with Fluorite lens element
Interestingly, the first commercially available camera lens to use fluorite, the Canon FL 300/5.6 introduced in 1969, also used two fluorite elements.
Feb 25, 2013 at 03:28 PM
StillFingerz
p.1 #13 · Canon Ultra Wides with Fluorite lens element
Peter, after I picked up my 1st T-90; in 86, and Canon subsequently KYed us buy dumping the FD line of lenses, I used my film gear a ton, took me a decade to un-piss my self off....not switch to Nikon. The investment was a lot for my wage level when orphaned...I was not happy.
The EOS-3 woke me up, hooked me on AF and USM...Canon had me by the short hairs once again, I've not really delved into lens element make up much. My professional interests lay elsewhere in bits-n-bytes and since 76 with that 1st Apple 1 that ball keeps-a-rollin. However time to read is here now so I will again begin to do so with lens element configurations/materials for those lenses in my kit and those the envy of my eye
Thanks Peter/Rob, off to the Canon museum I go...
Feb 25, 2013 at 03:35 PM
prairiewing
p.1 #14 · Canon Ultra Wides with Fluorite lens element
I still have that lens in a closet somewhere. I also had it's mate, the FL 500 5.6. They were both great lenses for their time.
Feb 25, 2013 at 03:43 PM
mpmendenhall
p.1 #15 · Canon Ultra Wides with Fluorite lens element
Well, then, pull it out of the closet and slap an EF mount conversion kit on it! If you don't want to bother with manual focus, I'm sure you can find someone else here who can put those lenses back to work.
Feb 25, 2013 at 03:46 PM
burningheart
p.1 #16 · Canon Ultra Wides with Fluorite lens element
Alright more flourite lenses to buy, better start saving my pennies, i mean nickels they discontinued our pennies.
Feb 25, 2013 at 04:54 PM
a.RodriguezPix
[X]
p.1 #17 · Canon Ultra Wides with Fluorite lens element
that's right on the money! wow, now you have to save 5 times as much!
Feb 25, 2013 at 05:04 PM
PetKal
p.1 #18 · Canon Ultra Wides with Fluorite lens element
BTW, I believe Robert might still own that fluorite 50-200L, and last time I spoke to him about it, he liked the lens.
Another one that was designed with a fluorite element was the economy priced 70-200 f/4 non-IS. However, that was then......new fluorite lenses will command new Canon prices which are invariably quite hurtful.
Feb 25, 2013 at 05:17 PM
burningheart
p.1 #19 · Canon Ultra Wides with Fluorite lens element
Just like the MDP, 200-1.8, and 50 1.0 though not in their league it has its own uniqueness, I like the colors it produces reminds me a lot of the good ole FD lenses.
Feb 25, 2013 at 05:29 PM
PetKal
p.1 #20 · Canon Ultra Wides with Fluorite lens element
No.... 100 % natural plastic finished in luxurious black leather texture.
Feb 25, 2013 at 06:47 PM
