Moderated by: Carl Auer, Fred Miranda
Sports Corner Rules
Sports Corner Resource
6D does HS Hoops
tshore
p.1 #1 · 6D does HS Hoops
Not sure whether this is best posted here, or on the gear forum, but I will go with this...
Got a 6D recently, as a complement to my 7D. The primary use for the 6D wasn't going to be sports, but I've been giving it a try shooting HS and youth hoops in the dim dungeons here in Marin County. I would say the 6D provides about 1 1/2 stops better high ISO performance vs the 7D. Huge difference! AF performance is just fine using the center AF point. Frame rate and speed writing to the buffer is glacial compared to the 7D. I wind up getting fewer, but better quality images using the 6D.
C&C welcome. (I know the WB is too blue..can never get it just right).
  Canon EOS 6D    70 mm    f/2.8    1/1000 sec    12800 ISO    0.0 EV
  Canon EOS 6D    80 mm    f/2.8    1/1000 sec    12800 ISO    0.0 EV
  Canon EOS 6D    50 mm    f/2.0    1/1000 sec    6400 ISO    0.0 EV
Feb 23, 2013 at 03:28 AM
CW100
p.1 #2 · 6D does HS Hoops
nice set, 12,800 ISO looks good, the WB may need some tweaking on some
Feb 23, 2013 at 01:12 PM
