Archive 2013 · Odd fractal looking "smudge" on lens that won't...
neil_johnson
p.1 #1 · p.1 #1 · Odd fractal looking "smudge" on lens that won't go away, internal?
Hello,
I noticed a smudge on my Canon 100mm f2.8 macro lens and thought it was a typical fingerprint but upon closer inspection looking very closely seems to resemble snow flakes, a fractal pattern or feathering.
I have cleaned with cleaner and microfiber and it doesn't seem to be on the surface. Any other ideas? Could it be a smudge on the inside? I don't think it could be moisture and why would moisture leave such an odd pattern?
Thanks
Feb 22, 2013 at 06:31 PM
Ian.Dobinson
p.1 #2 · p.1 #2 · Odd fractal looking "smudge" on lens that won't go away, internal?
ER, you won't like the answer.
That sounds like FUNGUS .
Can you post an image ?
Feb 22, 2013 at 06:35 PM
neil_johnson
p.1 #3 · p.1 #3 · Odd fractal looking "smudge" on lens that won't go away, internal?
I'll try to take a shot when I get home if it will even show up. Ironically I'd probably need my macro lens to best show the "smudge".
Hopefully its not a fungus though and not on the inside.
Feb 22, 2013 at 07:35 PM
dadgummit
p.1 #4 · p.1 #4 · Odd fractal looking "smudge" on lens that won't go away, internal?
Ouch, that is exactly what fungus looks like.
Feb 22, 2013 at 08:29 PM
Monito
p.1 #5 · p.1 #5 · Odd fractal looking "smudge" on lens that won't go away, internal?
Use a mirror?
Feb 22, 2013 at 09:13 PM
ZoneV
p.1 #6 · p.1 #6 · Odd fractal looking "smudge" on lens that won't go away, internal?
Any news on this?
Feb 26, 2013 at 01:13 PM
ciprian.trofin
p.1 #7 · p.1 #7 · Odd fractal looking "smudge" on lens that won't go away, internal?
Just a thought: can't you "burn" it out, with sun and a magnifying lens ?
Feb 26, 2013 at 01:22 PM
p.1 #8 · p.1 #8 · Odd fractal looking "smudge" on lens that won't go away, internal?
UV light should kill fungus, but it wo';t remove the residue, nor will it fix things if the fungus has etched the surface or eaten the glue between cemented elements. I've had about a dozen lenses with fungus that were checked by my local Camera Repair Centre. About half of them were repaired OK and the other half were thrown in the garbage.
Feb 26, 2013 at 01:28 PM
ZoneV
p.1 #9 · p.1 #9 · Odd fractal looking "smudge" on lens that won't go away, internal?
I am not sure wheter it is fungus or for example cristallisation pattern from sea humidity, or even others.
Fungus I would describe in most cases as spider web like.
Feb 26, 2013 at 02:15 PM
