       2       3       end
Samyang 24mm Tilt-Shift lens will retail for $999!
Admin
p.1 #1 · Samyang 24mm Tilt-Shift lens will retail for $999!
The new Samyang T-S 24mm f/3.5 ED AS UMC is finally available for pre-order.
The US retail price is set to $999. About half the price of the Canon TS-E 24mm f/3.5L.
The optical design comprises sixteen lenses arranged in eleven groups, including two aspherical lenses and two Extra Dispersion (ED) lenses. Each optical component has been covered with multi-layered, anti-reflective UMC coatings, which provide superb light transmission, high contrast and natural colors.
The Tilt-Shift design allows for smooth and fine adjustment of the focal plane by an angle of +/-8.5 and enables parallel shift of the optical axis by +/-12 mm.
Pre-order the Samyang T-S 24mm f/3.5 ED AS UMC at B&H Photo for $999
Also available for Nikon and Sony Alpha mounts.
Feb 19, 2013 at 12:52 AM
eskimochaos
p.1 #2 · Samyang 24mm Tilt-Shift lens will retail for $999!
Any release date info?
Feb 19, 2013 at 01:03 AM
JohnBrose
p.1 #3 · Samyang 24mm Tilt-Shift lens will retail for $999!
I've heard March-April, but they've been kinda slow on releases recently like their 24 f1.4. The pre-order is incouraging tho.
Feb 19, 2013 at 01:08 AM
eskimochaos
p.1 #4 · Samyang 24mm Tilt-Shift lens will retail for $999!
Awesome!! Looking forward to some resolution tests/lens rentals input.
Feb 19, 2013 at 01:12 AM
tsdevine
p.1 #5 · Samyang 24mm Tilt-Shift lens will retail for $999!
Hmm....16 elements in 11 groups...sounds familiar...
-Tim
Feb 19, 2013 at 01:15 AM
boingyman
p.1 #6 · Samyang 24mm Tilt-Shift lens will retail for $999!
Cool to hear the price. Anyone know if it can take screw on filters or a lee setup?
Feb 19, 2013 at 01:27 AM
EB-1
p.1 #7 · Samyang 24mm Tilt-Shift lens will retail for $999!
82mm. I'm not sure how shifting affects the use of rectangular filters, but it's probably similar to the Canon.
Feb 19, 2013 at 01:41 AM
vsg28
p.1 #8 · Samyang 24mm Tilt-Shift lens will retail for $999!
Decent price, and now I await reviews.
Feb 19, 2013 at 01:48 AM
RobDickinson
p.1 #9 · Samyang 24mm Tilt-Shift lens will retail for $999!
Yeah looks very interesting even though I have the canon already
Feb 19, 2013 at 01:52 AM
EB-1
p.1 #10 · Samyang 24mm Tilt-Shift lens will retail for $999!
I'm sure you would miss the electronic aperture (difference between TSE and TS).
Feb 19, 2013 at 01:56 AM
RobDickinson
p.1 #11 · Samyang 24mm Tilt-Shift lens will retail for $999!
Not really, better to see the real DOF, I use live view exp sim anyhow.
(I think I can even enable stopping down in Magic lantern, I should do ..)
Feb 19, 2013 at 02:01 AM
Bruce Sawle
p.1 #12 · Samyang 24mm Tilt-Shift lens will retail for $999!
I will await the reviews. Looking forward to seeing how it stacks up.
Feb 19, 2013 at 02:08 AM
sb in ak
p.1 #13 · Samyang 24mm Tilt-Shift lens will retail for $999!
Waiting for the tests. I may be in for one.
Feb 19, 2013 at 02:55 AM
PeakPhoto
p.1 #14 · Samyang 24mm Tilt-Shift lens will retail for $999!
Can't wait to see the reviews. I really want a tilt shift but this is much more in my price range than the Canon.
Feb 19, 2013 at 02:59 AM
Pixel Perfect
p.1 #15 · Samyang 24mm Tilt-Shift lens will retail for $999!
Is it a super-rotator design, as for me that's the huge benefit of the Canon?
Feb 19, 2013 at 03:15 AM
galenapass
p.1 #16 · Samyang 24mm Tilt-Shift lens will retail for $999!
If the optical quality is good then Samyang could really have hit a home run on this one - at that price point. Wow.
Feb 19, 2013 at 03:18 AM
skibum5
p.1 #17 · Samyang 24mm Tilt-Shift lens will retail for $999!
FWIW, Canon version has 16 elements with 3 UD and 1 aspherical.
Feb 19, 2013 at 03:32 AM
Bacalhau
p.1 #18 · Samyang 24mm Tilt-Shift lens will retail for $999!
B&H website is listing filters for the lens
looking at the lens picture, I can see threads inside the rim - one might assume that will take threaded filters at 82mm as according to specs
Feb 19, 2013 at 03:47 AM
sorpa
p.1 #19 · Samyang 24mm Tilt-Shift lens will retail for $999!
Looks like a great price.
Does it have independent rotation of tilt and shift?
Feb 19, 2013 at 03:54 AM
JohnBrose
p.1 #20 · Samyang 24mm Tilt-Shift lens will retail for $999!
Tilt and shift are independent similar to the nikon and canon versions.
Feb 19, 2013 at 03:59 AM
       2       3       end
       2       3       end
