Archive 2013 · Lens Service Tools - Where (and what) to Buy?
Gary Clennan
p.1 #1 · p.1 #1 · Lens Service Tools - Where (and what) to Buy?
Thought this may be the best place to post this. I am planning on doing a basic CLA on an older rangefinder lens ('70's era) and would like to know the essential tools needed. My plan is to clean the elements and lube the helicoid. Looks like I may need a spanner wrench, suction pen, micro screwdrivers, and some sort of cleaning supplies (sensor swabs?). Anything else which would be a benefit? Where is the best place to purchase? Any information would be most appreciated.
Feb 15, 2013 at 05:21 AM
LightShow
p.1 #2 · p.1 #2 · Lens Service Tools - Where (and what) to Buy?
These threads are a good start:
http://www.fredmiranda.com/forum/topic/806552
http://forum.mflenses.com/basic-techniques-to-repair-lenses-and-cameras-t32862.html
http://www.fredmiranda.com/forum/topic/810185 Lube: I like this stuff and apply alight coat with a 3mm paint brush to the helicoid.
http://www.fredmiranda.com/forum/topic/924310 Spanner: Love this spanner
WERA & Wiha drivers are good.(I think Japanese manufactures typically used JIS type screws)
[JIS is a specification for screw driver head design] but have used normal precision drivers without much problem, don't spend crazy money on them till you get your feet wet.
http://www.micro-tools.com/store/~/C-643/Precision-Phillips.aspx
http://www.micro-tools.com/store/~/C-671/Precision-Slotted-Screwdrivers-.aspx
http://ecx.images-amazon.com/images/I/41dtK%2Bd9ZhL.jpg
I've used a set like this for a while, I wrapped tape around the shaft for more leverage, and once in a while I had to modify a driver to fit a grub screw.
http://image.made-in-china.com/2f0j00WvpaThiqaYbd/Precision-Screwdriver-Set-52420-.jpg
For cleaning:
-Glass: PecPads and Eclipse and/or Ror, latex finger tip covers.
-For the metal bits: Varsol/lighter fluid, tooth brush, soap and water.
That should keep you busy.
Feb 15, 2013 at 07:46 AM
phuang3
p.1 #3 · p.1 #3 · Lens Service Tools - Where (and what) to Buy?
Thank you for the information. That's the exact screw driver you need to clean 5D2's viewfinder. I couldn't find any JIS type screw driver, but forced to use those phillips type. Finally, I got two worn out screws!
Feb 15, 2013 at 08:24 AM
Gary Clennan
p.1 #4 · p.1 #4 · Lens Service Tools - Where (and what) to Buy?
Thanks for the information!
Feb 15, 2013 at 02:37 PM
