It rated fairly well over at photozone, given he was testing a decentered copy apparently. I have never understood the allure of a fast 24 so no direct experience, sorry
According to Photozone's MTF measurements, the Samyang (Bower) 24mm f/1.4 has much better extreme border resolution at f/1.4, f/2 and f/2.8 than the more expensive Canon 24mm f/1.4L II, making it a great choice for night landscape photography at this price.
CA at these apertures is also better controlled on the Bower.
Ah night landscape. I guess it would be mostly stars then, since one would need to pretty much keep it focused to infinity for DOF reasons? (and/or with distant terrestrial objects and very little / no foreground) ?
Night landscape is an area I've rarely scratched, maybe that explains my confusion at fast 24mm
the 24 1.4 generally tested much more poorly than the samyang 14, 35, and 85, all of which tested very well. there were issues with claims of the lens really being an f2 (exposures very similar at f 1.4 and f2), and lenstip gave it a poor review, and photozone gave it a so so review. all that said, for the price, if you want 1.4, and can live without autfocus, its a nice lens. I always felt the 700 asking price was absurd. thier 35 1.4 has good for as little as 350.
If you want a 24 1.4, and you are on limited budget, go for it.
That's impressive considering how much of an improvement the Canon 24L II was over the mk1 version.
I am so tempted by this one, but I have to try and resist. Saving up for a white whale is hard when things like this pop up to lead me astray.
If you want a 24 1.4, and you are on limited budget, go for it....Show more →
I'm glad you mentioned Lenstip as I know they test for coma and astigmatism correction in their reviews.
I was wondering myself how the Canon and Bower (Samyang) 24mm f/1.4 lenses would compare in this regard.
From their tests, it was better corrected for coma than the Canon at f/1.4 and f/2. Although astigmatism didn't fare very well..
I think the truth of the matter is that a fast FF 24 is extremely hard to make. The Bower still reviewed better than the Canon L on Photozone. I do agree the $700 MSRP is pretty high, but considering the review and how much the L costs, it's not hard to believe. I think with time, as many things go, the price will/has come down.
"The Bower still reviewed better than the Canon L on Photozone"
Without wishing to appear gitty it did not. Yes in terms of resolution the Samyang was better in the corners at or near wide open, but in terms of central resolution at these fast apertures the Canon 24mm L f1.4 Mk2 was better. As it should be at that price of course. Fast wide lenses are hard to design with lots of compromises, the Samyang designers elected to have great corners, and the Canon designers elected to have great central performance:
Doesn't mean that the Samyang isn't a great lens and a super buy, but to say that it is a better lens that the L is debatable to say the least. For full disclosure if I dropped my L I would probably replace it with the Sammy for financial reasons, and would be delighted to have the latter lens. But that's not the same as saying that the L is eclipsed even in optical quality, before taking into account AF and automatic diaphragm etc.
I have the Samyang 24 and it is very sharp across the frame. Not quite as sharp as the Samyang 35 but still very good. The little bit advantage the Canon has isn't worth the price to me. My reasoning was I could by 2/3 very/very good lenses or one excellent Canon. Others will make a different decision
I'll admit I may have taken it a bit far to comment with the above quote. I was thinking of the verdicts, first sentence from each -
Samyang - "It may be a bit embarrassing for the original manufacturers but the Samyang 24mm f/1.4 ED AS UMC manages to produce a quality similar to its roughly double priced counterparts."
Canon L - "The Canon EF 24mm f/1.4 USM L II gave us some mixed feelings during the tests."
It is very true about the center (Canon) and borders (Samyang) though. The Samyang had less CA and vignetting too, but more distortion. At the end of the day, they are different lenses with different purposes and costs.
