Lowepro AW 400
crgb
p.1 #1 · Lowepro AW 400
Does anyone have any relevant info regarding Lowepro AW 400 as a carry on? I'm getting confusing information from Delta, and was hoping someone could provide me with a more reliable, experience based answer. Thanks in advance.
Feb 08, 2013 at 04:49 AM
Garrick L
p.1 #2 · Lowepro AW 400
I took my Flipside 400 AW on the plane recently both internationally and domestic flights and it fit in the overhead without any problem and was never told I couldn't carry it on. I always see people carrying on much larger bags than the 400 AW
Cheers,
Garrick Liddell Photography
Feb 08, 2013 at 01:53 PM
fairtex
p.1 #3 · Lowepro AW 400
I have no info about Delta, but the Flipside 400AW is that small that I never had problems with it on a plane.
Feb 08, 2013 at 02:34 PM
Roland W
p.1 #4 · Lowepro AW 400
The size allowance at Delta of 9 by 14 by 22 is technically not met by the Flipside 400 AW which is listed at 10 by 12 by 18, but that listed 10 inch dimension of the may be with the outer compartment filled with stuff. In practice you will likely never have a problem, but you may want to check that Flipside out in person, and see if you could move stuff out of that compartment temporally to get the bag to meet the 9 inch dimension. Once you get past any check, you can put the stuff back in there.
Feb 08, 2013 at 03:31 PM
