Moderated by: Steve Tinetti, Fred Miranda
Wedding Resource List
Sanity Check
cbradio09
p.1 #1 · Sanity Check
I can't images to look sharp on my website for the life of me. Export at 1001 on the long side, 72 dpi. and they look fuzzy on the webpage but sharp as all get out in PS.
What am I doing wrong? I'm using prophoto 4 with the most up to date wordpress. drag and drop uploading with no plug ins that mess with the image.
Thanks,
Cam
Feb 05, 2013 at 02:16 AM
SloPhoto
p.1 #2 · Sanity Check
looking at your page, I see nothing that is 1001 pixels
I see things that are ~915/867/615px wide.
Why do you export at 1001px?
Feb 05, 2013 at 02:24 AM
eephoto
p.1 #3 · Sanity Check
Ok, this may be a redundant question, but are you sharpening for the web?
Feb 05, 2013 at 02:29 AM
cbradio09
p.1 #4 · Sanity Check
yes on sharpening for the web, long edge is 1001 because that is the max width of the theme
Feb 05, 2013 at 02:31 AM
G-Gore
p.1 #5 · Sanity Check
On the blog all photos has either 867px wide (for horizontal layout) and 615px for verticals.
Maybe try exporting to those dimensions instead of 1001px wide.
Also on my screen the pics look pretty flat. Maybe when exporting to blog boost curves and saturation?
Feb 05, 2013 at 02:52 AM
TTLKurtis
p.1 #6 · Sanity Check
That may be the max width of the theme but not what size images it is showing. The problem is your site is scaling the images and not doing a good job of it apparently.
Feb 05, 2013 at 03:44 AM
cbradio09
p.1 #7 · Sanity Check
gotcha, thanks for the assistance fellas, exporting at max edge of 867 helps quite a bit
Feb 05, 2013 at 04:04 AM
Jamesbjenkins
p.1 #8 · Sanity Check
It's compression that's getting you. If you export too large for the margin set in your blog, your site will down-res to fit, which almost always results in softness due to interpolation.
Feb 05, 2013 at 03:41 PM
Prettym1k3
p.1 #9 · Sanity Check
I had this same problem. I set my image width on my blog to 800px wide. What I didn't know is that the blog template actually adds another 15 or 20 or 30px to the mix. So when I resized my images to 800px, they were too big (they should have been at like 780px or something). Once I resized my blog template width to 820 or 840 or something, then uploaded my 800px images, everything went just fine.
Compression is a helluva thing, man.
Feb 05, 2013 at 04:24 PM
cbradio09
p.1 #10 · Sanity Check
thanks for sharing that it happened to other people as well, i was loosing it last night trying to get the darn things to look sharp
Feb 05, 2013 at 04:35 PM
roland hale
p.1 #11 · Sanity Check
Prophoto also has an automatic "downsizing/resampling" option somewhere in the settings. There's a tutorial on their website for trouble shooting un-sharp images.
Feb 07, 2013 at 05:33 AM
