Archive 2013 · Nikon D700 Sensor Question
langda
p.1 #1 · p.1 #1 · Nikon D700 Sensor Question
A photographer that had just purchased a D700 with approx. 5000 actuations, reported having a problem with approx. 1 in 250 shots. He thinks the sensor is bad. Neither the previous owner or original owner reported seeing any problem with the camera.
The photo below was submitted as an example of the issue. Has anyone seen or heard of a similar case. Does this sound like sensor problem? If the sensor is " bad", why does it only exhibit a problem in so few photos? Could this be related to some seldomly used mode?
Any information / ideas would be appreciated.
Feb 03, 2013 at 03:10 AM
lukeb
p.1 #2 · p.1 #2 · Nikon D700 Sensor Question
Have two 700's - never experienced anything like what is here.
Feb 03, 2013 at 03:18 AM
skycolt
p.1 #3 · p.1 #3 · Nikon D700 Sensor Question
Is the pattern the same for all the bad photos? Always the bottom region?
Feb 03, 2013 at 03:20 AM
LarryBoy57
p.1 #4 · p.1 #4 · Nikon D700 Sensor Question
Memory card issue?
Edited on Feb 03, 2013 at 03:25 AM · View previous versions
snapsy
p.1 #5 · p.1 #5 · Nikon D700 Sensor Question
If it's only 1 in 250 it's likely a corrupt NEF rather than a sensor problem. I suggest he troubleshoot the media side of things, starting with his CF card, and moving on to the reader if necessary.
surreal612
p.1 #6 · p.1 #6 · Nikon D700 Sensor Question
It looks similar to this http://www.fredmiranda.com/forum/topic/1177194/0?keyword=bad,memory#11221853
Feb 03, 2013 at 03:32 AM
sbarricklow
p.1 #7 · p.1 #7 · Nikon D700 Sensor Question
Do you occasionally turn off the camera immediately after shooting a photo in an attempt to save the battery?
I experienced a similar problem that was a result of switching the camera off before the RAW image had been completely saved to the memory card. The camera was setup to save both a JPEG and RAW image. Once the habit was broken, the problem was solved.
Feb 03, 2013 at 04:05 AM
Dustin Gent
p.1 #8 · p.1 #8 · Nikon D700 Sensor Question
I bet it is the card. I had the same problem (but in a different spot) with a CF card and a 40D.
Feb 03, 2013 at 07:23 AM
Wes Bailey
p.1 #9 · p.1 #9 · Nikon D700 Sensor Question
I recently had a bad image image as above occur but only once. I believe it is because of the card. The bad image occurred when I used a Sandisk Ultra 8 GB - I now use a Sandisk Extreme 16 GB and no problems of late.
Feb 03, 2013 at 05:24 PM
