Handle for monopod
Michael White
p.1 #1 · Handle for monopod
I'm looking for a handle that will convert my monopod to a cane or walking stick. Does anyone know of one?
Jan 31, 2013 at 01:07 AM
Paulthelefty
p.1 #2 · Handle for monopod
Monopods are not designed for that much weight, unless you are only 50 lbs...
Paul
Jan 31, 2013 at 02:23 AM
Michael White
p.1 #3 · Handle for monopod
It is more of an easy way to walk with it and a little to cover up what it is.
Jan 31, 2013 at 04:17 AM
iweiner
p.1 #4 · Handle for monopod
michael, check out ll Bean and Eastern Mountain Sports for the round corkball head with lanyard. My Manfrotto 680B has the 1/4-20 and 3/38 screw thread and fits the 1/4-20 on the corkball head. In fact there an accessory mini-tripod leg set that screws in the bottom leg (for storage) and permits to cautiously use it a temporary tripod.
I comfortably mount my 70=200 and D800+battery grip on it while I reach into my bag or munch on a power bar.
I raise or lower the monopod height depending if I am going uphill, downhill or on level ground. If you undertake an African Safari in a Landrover this is what you will need.
If you weigh more than 50 lbs be certain to use the larger diameter legs first, I have not noticed any bending or permanent distortion in my decade of use.
Jan 31, 2013 at 05:17 AM
