LightShow Offline Upload & Sell: Off
p.1 #6 · Sigma 60mm f2.8 for E and m4/3 mount | |
I hope they're built to a higher quality level, the old ones felt like they would fall apart.
And it looks like they have kept the metal mounts.
60mm F2.8 DN – Featuring the natural perspective of mid-range telephoto lenses, together with a shallow depth of field, this lens allows the photographer to capture a single part of a subject with great bokeh effects. It has an angle of view equivalent to 120mm on the Micro Four Thirds system and 90mm on the E-mount system (35mm equivalent focal length). The minimum focusing distance is 19.7 inches; the maximum magnification is 1:7.2. This lens also contains Special Low Dispersion (SLD) glass, which helps minimize axial and transverse chromatic aberration.
Sigma 19mm F2.8 DN – This high-performance, wide-angle telephoto lens has an angle of view equivalent to 38mm on the Micro Four Thirds system and 28.5mm on the E-mount system (35mm equivalent focal length). As a wide-angle lens with excellent mobility, it is ideal for studio photography, architecture and starry skies. Its minimum focusing distance is 7.9 inches and its maximum magnification is 1:7.4.
Sigma 30mm F2.8 DN – This high-performance, standard telephoto lens has an angle of view equivalent to 60mm on the Micro Four Thirds system and 45mm on the E-mount system (35mm equivalent focal length). This lens, which is perfect for casual and formal portraiture, documentary photography, travelogues and everyday shooting, includes a double-sided aspherical lens that enhances its optical performance. Its minimum focusing distance of 11.8 inches and its maximum magnification is 1:8.1.
