Archive 2013 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
claymiller
p.1 #1 · p.1 #1 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
I have had no problem downloading raw files from my 7D but Elements 10 Organizer will not download from my new 5DMIII. Are Raw files different in the 7D vs the 5DMIII? Is there a patch to update this organizer? Please help! Thank you!
Jan 28, 2013 at 03:22 AM
Paul Mo
p.1 #2 · p.1 #2 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Update your software, including the latest RAW updates.
Jan 28, 2013 at 03:27 AM
Cicopo
p.1 #3 · p.1 #3 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
As above. I don't think I've seen one single camera model update use CR2's that were the same as older models. (the 20D to 30D might be an exception but I never checked).
Jan 28, 2013 at 03:32 AM
DanBrown
p.1 #4 · p.1 #4 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Here is the link for Camera Raw version 6.7 which supports the 5D Mark III.
Jan 28, 2013 at 03:41 AM
jstntym
p.1 #5 · p.1 #5 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
With my 5DMkIII I transfer 8bit TIFF from DPP into Elements9 for and additional tweaks and convert to high quality jpegs for web use..
Jan 28, 2013 at 04:00 AM
EB-1
p.1 #6 · p.1 #6 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
It is better to convert the CR2 file to a 16-bit TIFF if you plan to tweak the image before creating the final output.
Jan 28, 2013 at 04:55 AM
BuceG
p.1 #7 · p.1 #7 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
EBH - PSE9 is basically an 8-bit program. There is only limited support for 16 bit image editing (you can't use layers without converting to 8 bit).
- Bruce
Jan 28, 2013 at 05:12 AM
Imagemaster
p.1 #8 · p.1 #8 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
But where is the link for Apple support of 5D3 RAW files
Jan 28, 2013 at 06:33 AM
Gochugogi
p.1 #9 · p.1 #9 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
http://support.apple.com/kb/DL1604?viewlocale=en_US&locale=en_US
5D3 support was added to Apple's Digital Camera RAW several versions back, I think Spring 2012. Anywho, the latest Digital Camera RAW is 4.03 and added the 6D last December. However you need to run the latest versions of Aperture or iPhoto to use recent Digital Camera RAW updates.
Jan 28, 2013 at 07:18 AM
Imagemaster
p.1 #10 · p.1 #10 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Since I don't use either Aperture or iPhoto, their update does not work for me. I never had to use either of those in the past. Why should I have to use them now?
Jan 28, 2013 at 04:42 PM
Gochugogi
p.1 #11 · p.1 #11 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Why did you ask for the Apple RAW update if you don't use Apple products?
I like Aperture but the choice between using it or LR comes down to personal preferences. I was a LR early adopter but didn't care for the interface and Aperture fit work flow better.
Jan 28, 2013 at 05:14 PM
Imagemaster
p.1 #12 · p.1 #12 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Because I use an iMac with my CS5.
Jan 28, 2013 at 06:43 PM
DanBrown
p.1 #13 · p.1 #13 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
The OP asked for an update to allow Elements 10 to import 5D Mark III files. That's what I supplied.
The updates to the Apple OS (which includes updates to the camera profiles) are available through the software update process (which usually creates an automatic notification that an update is available). Or, updates can be downloaded through support.apple.com.
Jan 28, 2013 at 07:08 PM
Imagemaster
p.1 #14 · p.1 #14 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Thanks, I am aware of that. My question also applies to others reading the thread.
A Google search shows that Apple has not provided an update that will display RAW thumbnails for OS 10.6.8. and I have the latest updates.
Jan 28, 2013 at 08:02 PM
DanBrown
p.1 #15 · p.1 #15 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Apple released RAW compatibility update 3.12 for 10.6.8 in April, 2012. That update had only one feature, namely support for the 5D Mark III for Aperture and iPhoto 11.
Jan 28, 2013 at 08:29 PM
Imagemaster
p.1 #16 · p.1 #16 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
That is my point. Why is the support only for Aperture and iPhoto, when in the past it has always been for the operating system?
Jan 28, 2013 at 09:44 PM
DanBrown
p.1 #17 · p.1 #17 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
What is it that you are attempting to do and find yourself thwarted?
Jan 28, 2013 at 10:45 PM
claymiller
p.1 #18 · p.1 #18 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
Thank you Thank you Thank you! It may have been helpful to include my hardware is a second generation Mac Floor model that does support 16 bit processing (which is why I bought it on Craigslist last year for $1100). Thanks for the fix!
Jan 29, 2013 at 01:32 AM
Imagemaster
p.1 #19 · p.1 #19 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
When I download RAW images to my iMac, they appear in my download folder as RAW icons, and not as thumbnail images like they should with every other Canon camera I have ever owned.
http://forums.dpreview.com/forums/thread/3220775
https://discussions.apple.com/thread/3972859?start=0&tstart=0
http://forums.dpreview.com/forums/post/41789682
http://designgard.com/topic/280078/camera-raw-plug-in-for-mark-iii/#550476
Jan 29, 2013 at 02:15 AM
Imagemaster
p.1 #20 · p.1 #20 · Adobe Elements 10 Organizer Won't download Raw from 5DMIII
bump
Feb 16, 2013 at 03:23 AM
