100mm square filters Tokina 16-28mm
scottleslie
p.1 #1 · 100mm square filters Tokina 16-28mm
I have purchased a tokina 16-28mm for my d800 and am wondering if a 100mm square ND filter (hand held against the hood) will vignette at 16mm. I know the diameter of the hood is about 92mm, but am not sure if the 100mm is enough to cover the corners. I am not interested in using a filter holder, I've always just hand held. Thanks very much!
Jan 27, 2013 at 11:58 PM
scottleslie
p.1 #2 · 100mm square filters Tokina 16-28mm
Anybody?
Jan 28, 2013 at 06:34 PM
Brad K
p.1 #3 · 100mm square filters Tokina 16-28mm
Hi Scott,
I like filter questions and I think this one deserves a response although, personally, I can't provide any direct experience with this lens. I can say that I've shot with a 100mm square filter in a filter holder as the third filter out from a 17mm (non-bulbous) lens and that worked ok. I think your idea has a decent chance of working since the built-in hood doesn't appear to extend excessively far beyond the element however even if the coverage is ok, you'll have to find a way to block reflections onto the lens-facing side of the filter. Since you have the lens, you could probably check coverage with a cut 100mm square piece of paper.
Jan 29, 2013 at 02:44 PM
Javier Munoz
p.1 #4 · 100mm square filters Tokina 16-28mm
I think that you need 6" filters if you want to cover the wide end.
Jan 29, 2013 at 03:03 PM
kpc49
p.1 #5 · 100mm square filters Tokina 16-28mm
In theory as long as you have it directly up against the lens hood there shouldn't be any vintaging because the filter is wider then the lens hood and it's at relatively the same distance away from the front lens element. As long as you don't bring the filter in front of the lens too far you should be good.
I don't own this lens, but the logic behind it makes sense.
Jan 29, 2013 at 06:35 PM
lou f
p.1 #6 · 100mm square filters Tokina 16-28mm
my 16-35 vr is fine with my lee kit if thats any use. it shoud be just fine.
Jan 29, 2013 at 06:41 PM
scottleslie
p.1 #7 · 100mm square filters Tokina 16-28mm
Thanks for the replies. I don't have the lens yet (it has been shipped to me from the US), so I wanted to preemptively order a filter to save time. I suspect 100mm will be wide enough for about 18-19mm.
Jan 30, 2013 at 12:24 AM
runamuck
p.1 #8 · 100mm square filters Tokina 16-28mm
100 MM is measured across the flats. The diagonal would be somewhere around 170 MM if my trig is any good.
100 MM is also 4 inches roughly, and the diameter of the lens is 3 1/2 inches, so a 100 MM filter would cover quite well.
Sorry, I haven't used any trig since I retired.
Jan 30, 2013 at 02:36 AM
