One new topic per day
Shay's Run, second set
dsjtecserv
p.1 #1 · Shay's Run, second set
Here are the rest from Shay's Run, West Virginia in October.
This log in the outlet below the second falls had become hollowed out like a trough. Still not sure this quite works, but here it is for your comments.
The next three are all from virtually the same location just below the third falls, where the creek cascades steeply through a tunnel of overhanging trees. Joe Rossbach had a cover of Outdoor Photographer from this spot a couple years ago.
2.
3.
4.
I'd welcome any comments or suggestions.
Dave
Jan 25, 2013 at 11:32 PM
Callisto
p.1 #2 · Shay's Run, second set
Dave,
I always enjoy your work - the pano is totally superb and is my fav. - RC
Jan 26, 2013 at 02:43 AM
blueshadows
p.1 #3 · Shay's Run, second set
Very elegant, David, as usual for you. The depth in the second and third is wonderful.
Jan 26, 2013 at 04:50 AM
kwilliam8
p.1 #4 · Shay's Run, second set
Dave, these are great. But the third image is just stunning!
Keith W.
Jan 26, 2013 at 08:10 AM
JimFox
Moderator
p.1 #5 · Shay's Run, second set
Wow Dave! These are really sweet looking.
I really like the canopy created by the trees and the bit of mist in #2 and 3. I can't choose between those two as they both give two different feels. #1 and 4 are also great. I would love to give you suggestions, but I sure think that you nailed these babies!
Jim
Jan 26, 2013 at 09:03 AM
DSC01
p.1 #6 · Shay's Run, second set
Dave, the work is beautiful and the pano is one of the best fall shots I have ever seen. It is so well composed it contains every element I would want in a fall shot pulled together perfectly, really excellent job ! Regards, Dean
Jan 26, 2013 at 02:23 PM
dsjtecserv
p.1 #7 · Shay's Run, second set
Well thanks everyone. I really appreciate the comments. Shay's Run is a cool place to return to; it has been different every time I've been there. This is the fist time I timed it close to right for the optimum colors.
Incidentally, with the exception of #2, these are all technically panoramas. 1 and 4 are also stitches of at least 3 frames, with a wide angle focal length and camera in portrait orientation.
Dave
Jan 26, 2013 at 04:14 PM
helenica
p.1 #8 · Shay's Run, second set
Great work with believeable colours.
Jan 26, 2013 at 04:25 PM
Sunny Sra
p.1 #9 · Shay's Run, second set
David,
#2 and #3 are absolutely fantastic. Beautifully done.
Jan 26, 2013 at 04:40 PM
Picture This!
p.1 #10 · Shay's Run, second set
great set. Well done.
Jan 26, 2013 at 04:43 PM
CorwinGraves
p.1 #11 · Shay's Run, second set
Great stuff here - really like #3, but all are fantastic. Can I ask what you are using to lengthen the exposure - an ND or polarizing filter?
Jan 26, 2013 at 04:49 PM
dsjtecserv
p.1 #12 · Shay's Run, second set
Thanks Helen, Sunny, Manu and Corwin. Unless it is sunny I usually find that a polarizer is enough to get me into the 1/5 to 1/2 second range that I like for most moving water shots. But if I need more I am most likely to keep the PL on, but add a 2 to 3 stop ND and adjust ISO to bring the shutter back where I want it.
Dave
Jan 26, 2013 at 05:11 PM
dbehrens
p.1 #13 · Shay's Run, second set
Oh yeah! #3 and #1 are phenomenal! The other two are just plain good! Dave
Jan 26, 2013 at 07:23 PM
Jon Buffington
p.1 #14 · Shay's Run, second set
I love #1. #3 then #4. Beautiful images and expertly captured!
Jan 26, 2013 at 08:01 PM
Kenneth Kosler
p.1 #15 · Shay's Run, second set
Beautiful set here, #2 & #3 are my picks of this awesome set, nice.
Jan 26, 2013 at 08:44 PM
Scott Kroeker
p.1 #16 · Shay's Run, second set
Great series David. I enjoy them all!
Jan 27, 2013 at 02:48 AM
vibhav
p.1 #17 · Shay's Run, second set
This is just amazing stuff... Absolutely beautiful and very inspirational.... Very hard to pick any favorite as each one is awesome in its own right... super! Thanks for sharing...
Jan 27, 2013 at 04:51 AM
dsjtecserv
p.1 #18 · Shay's Run, second set
Thank you, everyone. I really appreciate your comments and your indication of your preferences.
Dave
Jan 27, 2013 at 06:40 PM
Rob Tillyer
p.1 #19 · Shay's Run, second set
Wonderful work #3 is just outstanding.
Rob
Jan 27, 2013 at 10:42 PM
Nigel Turner
p.1 #20 · Shay's Run, second set
Hi,
Very nice images. Not sure if I would go so wide on the pano as you kind of loose the focal point of interest.
I do like the second image though and feel that a very strong image would have been the top half of the frame with just the trees.
I more often than not find that a lot of landscape photographers try to add to much into the image, when often 'less is more' if you know what I mean.
Personally I'd die to be in amongst that lot with such potential!
Again.. very nice images, well done.
Nigel.
Jan 27, 2013 at 11:53 PM
