NathanHamler Offline Upload & Sell: Off
p.1 #5 · Built in Interval function | |
I've used the intervalometer more than a few times for start trails....only problem is, on the D300 and D7000, there seems to be a glitch, where if you're doing long exposures, like 30 sec each, and you tell it 1 sec in between frames, for like 60 frames....well it'll end up stopping after a couple shots....it's really weird...so what i do whenever i use that function, is i tell it to do 999 frames, and then i just stop it manually after i think i got enough.....first time it happened i kept setting it, and it would stop, and i'd set it again, and it would stop....so i googled it later and sure enough other people had the same problem...the camera seems to factor in the shutter speed, and thinks that you should wait at least 30 sec between shots if you're using a 30 sec shutter speed.....which isn't good for start trails at all.........not sure if it carried over to the D4, or other recent bodies....
