ADVICE: Zuiko 24mmMC/35mmSHIFT MC for 17-55/2.8?
prashant
p.1 #1 · ADVICE: Zuiko 24mmMC/35mmSHIFT MC for 17-55/2.8?
I have enjoyed both the Zuiko a lot and have made nice images with it. However I need an AF lens and 17-55 looks like a nice choice for Rebel. I also have 24mm TS-Ei so Zuiko Shift do not see much use. Just thought of gathering advice before the plunge.
Jan 20, 2013 at 10:44 PM
LightShow
p.1 #2 · ADVICE: Zuiko 24mmMC/35mmSHIFT MC for 17-55/2.8?
I'm not sure but I think there is a mkII of the 17-55, the AF zoom question will get better/more of a response in the Canon forum.
Jan 20, 2013 at 11:54 PM
melcat
p.1 #3 · ADVICE: Zuiko 24mmMC/35mmSHIFT MC for 17-55/2.8?
I have the Zuiko 24mm f/2.8 and the non-MC version of the 35mm f/2.8 and IMO either one would merit a switch to full frame. If that 24mm TS-E is the Mark II, I would say without doubt you should do that; I have that lens too. All three are sharp out to the corners when modestly stopped down. If it's the Mark I TS-E you have, it's said to be not as good, but then again the Zuiko 35mm shift does on full frame most of what the TS-E did on 1.6 crop.
Once you got that APS-C zoom you'd be locked in to APS-C. If 12Mpx is enough resolution, consider a used 5D. Then think carefully about what you need AF for: perhaps Canon's inexpensive 85mm f/1.8 would do it, or their 35mm f/2 IS. If it's for people shots, perhaps a non-DSLR would do the job and be more portable.
Jan 21, 2013 at 08:07 AM
