I.G.I. Offline Upload & Sell: Off
| p.1 #1 · EIZO CG&Colornavigator question | |
Hi, a question to all of you using Eizo's ColourGraphic series monitors in conjunction with the Colornavigator. Recently bought the CG223W, so far very pleased with the quality (to my surprise and delight it came with the factory quality control individual measurement sheet), except for one UI annoyance.
Monitor profiles can not be changed as customary from the System Preferences/ Displays but only from the monitor menu. This would've been fine for me as there are three options for custom calibrated profiles; or so I though... As I read in the manual, and subsequently confirmed in practice, the CAL1, 2, and 3 are not three options for each input signal (connection to the PC), but only one of them corresponds to each of the input signal connections. In other words, in the monitor menu I can store only one custom profile at a time. To toggle between several custom profiles I have to open the Colornavigator. No need to tell, I find this very inconvenient.
Is there a way to circumvent this annoying shortsightedness and assign CAL1, 2, and 3 to custom profiles while using the same PC monitor connection?
