Alterenative to card in cam cf card(reader)
Xandervt
p.1 #1 · Alterenative to card in cam cf card(reader)
After 4 broken cardreaders and a broken extreme 3 the card readers seems to damage my CF cards. Besides the in camera canon slot witch brand is a good brand to use?
Jan 16, 2013 at 05:35 PM
ardvorak
p.1 #2 · Alterenative to card in cam cf card(reader)
I've had no issues whatever with my Lexar Professional USB 3.0 card reader:
http://www.lexar.com/node/4577
Got mine on Amazon and recently updated the firmware.
Jan 16, 2013 at 06:19 PM
p.1 #3 · Alterenative to card in cam cf card(reader)
Man, you're tough on cards! I been using a Lexar Dual Slot USB 3.0 reader for almost two years, with no problems (excellent reader). Before that, I had a multi-card reader that I used for about six years, no problems. It was Lexar or some other recognizable first-tier brand, but nothing too special.
Maybe you should drink less coffee, or something...
Jan 16, 2013 at 06:22 PM
Xandervt
p.1 #4 · Alterenative to card in cam cf card(reader)
it wasn't the coffee I guess but the cheap card reader....thanks!
Jan 16, 2013 at 06:52 PM
runamuck
p.1 #5 · Alterenative to card in cam cf card(reader)
I doubt it's the card readers. After 4 readers, it's most likely operator error. I suggest leaving the card in the camera and uploading photos using the camera's USB connection. Just reformat the card after each upload.
Jan 16, 2013 at 07:24 PM
p.1 #6 · Alterenative to card in cam cf card(reader)
runamuck wrote:
...I suggest leaving the card in the camera and uploading photos using the camera's USB connection..
A card reader is way faster.
Jan 16, 2013 at 07:26 PM
runamuck
p.1 #7 · Alterenative to card in cam cf card(reader)
I have a reader for CF cards that cost $1.99 or so. It still works after several years.
Jan 16, 2013 at 07:30 PM
tonykriegmaui
p.1 #8 · Alterenative to card in cam cf card(reader)
Can anyone tell me what I might be doing wrong. It seems that any card above 1 mb in a card reader doesn't mount on any of my MAC's so I end up using the usb to MAC upload
Jan 16, 2013 at 08:27 PM
Xandervt
p.1 #9 · Alterenative to card in cam cf card(reader)
The first reader held several Years and went down because of the elektronic in the reader The second card reader held a few weeks. I can imagine that second card reader damaged one cf card (8gb extreme 3) witch i noticed too late. I shoot 70000 shots a year with at least 200 card readschanges cam/reader a year so operator error I think is not so likely. The slide system in my 1dm3 is way way better than the card readers i had were. The in cam usb is way way slower. As is semi pro with 20 - 30 Weddings a year the time I save with a card reader is welcome.
Thanks for the posts above!!
Jan 16, 2013 at 08:58 PM
Xandervt
p.1 #10 · Alterenative to card in cam cf card(reader)
Bought a Lexar Professional USB 3.0 on Ebay
Jan 16, 2013 at 09:14 PM
Gochugogi
p.1 #11 · Alterenative to card in cam cf card(reader)
Sounds like the OP needs the PixelFlash USB 3.0 No-Bend Pins Compact Flash Memory Card Reader:
http://www.amazon.com/PixelFlash-No-Bend-Compact-SuperSpeed-Adapter/dp/B005IMFX2K/ref=sr_1_fkmr0_1?ie=UTF8&qid=1358371989&sr=8-1-fkmr0&keywords=CF+card+reader%2C+no+broke+pins
Tight guides and deep placement make it really difficult to mess up your pins...
Jan 16, 2013 at 09:35 PM
p.1 #12 · Alterenative to card in cam cf card(reader)
Xander will be OK with the Lexar Pro USB 3.0, as long as he doesn't drink coffee in the Coffeeshoppe.
Edited on Jan 16, 2013 at 09:44 PM · View previous versions
Xandervt
p.1 #13 · Alterenative to card in cam cf card(reader)
Thanks Gochuggi! If the Lexar Professional USB 3.0 doesn't work properly I buy that!
Xandervt
p.1 #14 · Alterenative to card in cam cf card(reader)
Allthough I live in the Netherlands I don't use that kind of Coffeee
Jan 16, 2013 at 09:46 PM
BiggHarry
p.1 #15 · Alterenative to card in cam cf card(reader)
I "second" this opinion
This card reader work very well.
Jan 16, 2013 at 11:49 PM
Paul Mo
p.1 #16 · Alterenative to card in cam cf card(reader)
+1 They're a good choice.
Jan 16, 2013 at 11:53 PM
firstgear99
p.1 #17 · Alterenative to card in cam cf card(reader)
All readers for cards have "rails" that make sure the card is positioned squarely to the pins. If you hurry the insertion, you run the risk of a sideways insertion as opposed to a straight on insertion. If you have to force the card, you have positioned it sideways and messed up a pin or two.
Take your time. I would suggest putting the card on the rails, slide it back & forth a couple of times, then inserting it squarely.
Operator error is the most likely cause of your problem. Sorry to say.
Jan 19, 2013 at 06:10 PM
