Older Tamron SP Adaptal Lenses
StillFingerz
p.1 #1 · Older Tamron SP Adaptal Lenses
Has anyone used the old Tamron SP Adaptal lenses on Canon EOS bodies...and successfully gotten infinity focus?
I've several pristine primes and zooms, all with the FD mount, but would buy an adapter and a Nikon or whatever adaptal mount is needed to use them.
Any advice/experience on how to use this old glass would be greatly appreciated.
Jerry
Jan 08, 2013 at 01:53 PM
RustyBug
p.1 #2 · Older Tamron SP Adaptal Lenses
Adaptall F mount on lens with F-EOS adapter works fine. Other mfr combinations likely to work also. I've got the venerable SP 90/2.5. The SP 17/3.5 is a very popular one as well ... as are other combinations. It is very doable.
Jan 08, 2013 at 02:56 PM
buggz2k
p.1 #3 · Older Tamron SP Adaptal Lenses
I haven't tried infinity with mine yet, Tamron 70-150/2.8 Soft Focus.
http://www.fredmiranda.com/forum/topic/1164951
Jan 08, 2013 at 03:32 PM
p.1 #4 · Older Tamron SP Adaptal Lenses
No worries. I've used many older SP Adaptall-2 lenses on my EOS cameras, with infinity focus. I have a couple of A2 to EOS adapters; they work well but they're relatively expensive. In many cases, it's more cost effective to get an A2 to M42 and M42 to EOS adapter set. Not quite as solid as the A2 to EOS, but generally less expensive and quite satisfactory.
Here`s the manual focus SP lenses that I found were pretty excellent. The last one (35-80mm) is a real sleeper. You can often find one for about $75 on eBay and it`s darn nearly as good as the Contax Zeiss 35-70/3.4 (which is a significant feat).
SP 17/3.5 [151B]
SP 180/2.5 LD IF
SP 300/5.6 Tele Macro [54B]
SP 35-80/2.8-3.8
Here's a good online resource site for Tamron manual focus lenses, http://www.adaptall-2.org/
Jan 08, 2013 at 03:33 PM
Bifurcator
p.1 #5 · Older Tamron SP Adaptal Lenses
There are EOS (EF) mounts in Adaptall II format already. Have been for several years now.
$17.00 and lower on the bay...
Jerry, or did you mean Adaptall v1 ?
BTW, if you're looking for image sample by chance there are couple of threads here:
http://www.fredmiranda.com/forum/topic/1056057/0
http://www.fredmiranda.com/forum/topic/933378/0
Jan 08, 2013 at 08:28 PM
p.1 #6 · Older Tamron SP Adaptal Lenses
It must be Adaptall-2, if it's an SP lens.
Jan 08, 2013 at 09:14 PM
harvey steeves
p.1 #7 · Older Tamron SP Adaptal Lenses
probably means the original Tamron EOS Adaptall II mounts which were extremely rare and didn't have the AF confirm contacts.
Jan 09, 2013 at 12:44 AM
roboticspro
p.1 #8 · Older Tamron SP Adaptal Lenses
Hi Jerry,
I have been using the 17, 28-80, 35-80, 90 Macro, and 500mm reflex on all the EOS bodies, with no problems at infinity, with a standard Tamron to EOS adapter (Rainbow Imaging).
Regards,
Edd
Chipped SP 500mm f8 Reflex
SP 500mm f8
  Canon EOS REBEL T1i    0 mm    f/0.0    1/500 sec    400 ISO    0.0 EV
SP 500mm f8 (chipped - set to f5.6 to trigger focus confirm)
  Canon EOS 5D Mark II    500 mm    f/5.6    1/800 sec    320 ISO    0.0 EV
Edited on Jan 09, 2013 at 02:09 PM · View previous versions
Jan 09, 2013 at 01:49 AM
Pedro Claro
p.1 #9 · Older Tamron SP Adaptal Lenses
I've used two lenses a few years ago: 28/2.5 [02B] and SP 300/5.6 [54B]. I had an A2-OM mount + OM-EOS adapter and it worked just fine. The 02B was a nice, moderately sharp and compact lens but with very cold colour reproduction (giving a very "1980's postcards" look to the images), while the 54B was a good tele lens with a very usefull MFD, allowing some interesting close-ups.
Jan 09, 2013 at 11:01 AM
Peire
p.1 #10 · Older Tamron SP Adaptal Lenses
SP 300/5.6,SP 90/2.5 (newer),SP 500/8 (newer),Tamron 28-80/3.5-4.2 with C/Y adaptall mounts+C/Y-EOS adapter.All good/very good with some caveats on 5D2/7D/600D.
Jan 09, 2013 at 01:16 PM
