What are the criteria?
narcissus
hypotyposis
p.1 #1 · narcissus
Suggestions on how to compose this photo differently, etc.? I'm not sure what to do with the stem either, as that's bothering me. Thanks!
Jan 06, 2013 at 01:28 AM
RustyBug
p.1 #2 · narcissus
Not a flower guy here, but I'd like to see the stem be a leading line from the foreground (bottom left portion of frame) and maybe something to prop under the flower to lift/rotate it toward the camera a bit more.
Jan 06, 2013 at 01:46 AM
Camperjim
p.1 #3 · narcissus
Try cropping in tighter. There is too much background and not enough flower.
Focus seems to be an issue. I don't know your f stop but I think you needed to shoot with a much higher f stop.
These flowers seem to be lying down on the job. Shooting with a vertical orientation would have helped.
The background is close and has hue and value similar to that of the flowers. I would suggest a different background especially darker and further away.
Jan 06, 2013 at 01:23 PM
sbeme
p.1 #4 · narcissus
I agree with Jim's points.
Here is a re-work to illustrate several potential improvements.
First, I rotated the image 90 degrees for a vertical orientation. Then I rotated the flowers as much as I could to get a bit of a diagonal flow across the image from bottom l to top right to add some dynamism. This was limited by the crop.
I then set black and white points, which essentially adds contrast, improves some of the flatness of the original image. I bumped vibrance. I reduced clarity, consistent with the soft look you already had and the flowers as subject. I added some aggressive sharpening.
Finally I added a negative vignette to fade the background away from the flowers, continue the soft look, and diminish the stem.
Done in LR.
Lastly I cycled through Fred's mats/frames. Not really happy with any of them here, but I chose one anyhow to formalize the presentation.
Scott
Jan 06, 2013 at 01:40 PM
ben egbert
p.1 #5 · narcissus
Very nice job Scott.
Jan 06, 2013 at 03:58 PM
Camperjim
p.1 #6 · narcissus
Scott, really nice rework. I would not have thought that much improvement was possible without reshooting.
Jan 06, 2013 at 05:54 PM
RustyBug
p.1 #7 · narcissus
+1 @ Nicely done.
Jan 06, 2013 at 09:11 PM
hypotyposis
p.1 #8 · narcissus
Done in LR.
Scott
Thanks, Scott! These were helpful changes that made the photo really gets away from the flatness.
Jan 07, 2013 at 07:26 AM
sbeme
p.1 #9 · narcissus
Ben, Kent, Jim
Glad it worked well.
Scott
Jan 07, 2013 at 12:18 PM
sbeme
p.1 #10 · narcissus
Thanks Priscilla.
Glad it helped.
Scott
