  Pre-order Rokinon 16mm f/2 ED AS UMC
Nikon D7000 glitch...please help!
liao24hoho
p.1 #1 · Nikon D7000 glitch...please help!
I've used my D7000 for one year and I love it.
But yesterday when I wanted to eject my flash light,it did not work,
There is this normal click sound that the camera is trying to push out the flashlight but the flashlight did not eject at all.I know how to operate my camera so I know something has gone wrong.
I went to Sequoia Park a week ago so it may be the low temp that caused the problem.
When I exert some force at the edge of the flashlight module as the same time I press the flashlight button I can open the flashlight and can use the flashlight as normal.
Do not know how to fix it.
pls help...........
Jan 02, 2013 at 08:22 AM
leighton w
p.1 #2 · Nikon D7000 glitch...please help!
Check to see if any debris is making it stick. Either that, or send it to Nikon or live with it. If it were mine, I'd probably live with it considering how many times I'd actually use it.
Jan 02, 2013 at 11:09 AM
Gregstx
p.1 #3 · Nikon D7000 glitch...please help!
It should be a pretty simple release. Once it is open, a thorough inspection should tell if there is debris or some other issue causing it to stay locked down. But it does require the camera to be turned on so there might be some internal electrical issue.
FWIW, Leighton, I use my built in flash quite often. Whether it is to trigger my 2 - SB800's or just for fill.
Jan 02, 2013 at 02:46 PM
davidnholtjr
p.1 #4 · Nikon D7000 glitch...please help!
I'm totally confused. Flash light
I'm guessing you mean the pop up flash?
If so, then it sounds like maybe the spring has broken that pop's it up.
Jan 02, 2013 at 10:09 PM
