JimFox Offline Upload & Sell: On
p.1 #4 · Trouble holding the D800 level | |
As John mentioned, I would turn on the gridlines, that should help you. I pretty much only use mine on a tripod and then use the gridlines to compose with, so I can't say that I have the same issue as you, but if I did, I would just use the gridlines until I got used to the difference.
Jim
