Alan321 Offline Upload & Sell: On
p.1 #2 · Questions on monitors, resolution, etc. | |
what matters most for photo editing are:
1. accurate colours and tones
2. wider colour gamut
3. pixels per inch (higher makes smoother image on screen)
4. inches (vertical and horizontal)
5. Being able to display suitable brightness levels in the range of about 90-140 Cd/m2. (anything more is just too bright and if you can't get this low then you'll always think that your prints are too dark)
Items 3 and 4 combine to give you the "resolution" in pixels as well as the physical size that you'll be looking at. If you can, get a 16:10 ratio monitor instead of 16:9 because the extra height is useful for viewing the portrait orientated photos without making them look too small. I personally dislike 90 ppi at normal viewing distance and prefer more than 110 ppi, but too small makes it hard to see. Big monitors at high ppi are hard or impossible to come by.
The graphics card is pretty much irrelevant so long as it can produce the required number of pixels. It does not have to produce them especially fast and so having a more powerful card is largely useless for photography - with some exceptions... Having a more powerful card allows some software to utilise the graphics card processor to help the main cpu speed up some operations. However, some people report that Ps, for instance, goes a little slower in the routine activities and what it speeds up is often unused. Ps is very comprehensive and does a lot that we don't need.
Apparently you cannot run a non-thunderbolt Apple monitor off the Apple thunderbolt monitors, in case you ever want more than one. If you have only one thunderbolt port then be aware that devices including monitors like to be at the end of the tb chain, but not all devices have a second tb port to connect the next device to.
Otherwise, I know nothing specific about those monitors. Just for kicks, have a look at what an NEC PA monitor or Eizo monitor can do, and then see what you're satisfied with.
- Alan
