Greg Campbell Offline Upload & Sell: Off
p.1 #9 · Assembling Time Lapses | |
I don't recall exactly, but I think it was somewhere around 1 frame per second running on a 2GHz laptop. Any halfway modern desktop CPU will churn out many frames per second. Multiple cores help too.The incoming files were 8MP jpegs. The program did two x/2 size reductions, then some brightness/contrast tweaking, then some sharpening before adding the resultant frame to the film. (Adding filters and effects is VERY easy, and you can stack, order, disable/enable reach filter as needed.)
The only tricky part is that all the image files must be sequentially numbered. If shooting RAW, set your batch processor to start a new file name sequence like "File0001.xxx"
See also http://www.fredmiranda.com/forum/topic/1175843/0#11208928
Edited on Dec 29, 2012 at 02:51 AM · View previous versions
