Archive 2012 · TTL cord with AF assist light?
joshmitchell
p.1 #1 · p.1 #1 · TTL cord with AF assist light?
I just switched over to Canon. When I used Nikon before I had an SC29 TTL Cord that had an AF assist light on the top of it that made it extremely useful for low light situations. Anyone know if there is a Canon equivalent?
Dec 17, 2012 at 01:56 AM
ZWhitford
p.1 #2 · p.1 #2 · TTL cord with AF assist light?
I'm in the same boat. Thanks for posing the question!
Dec 17, 2012 at 02:09 AM
kdlanejr
p.1 #3 · p.1 #3 · TTL cord with AF assist light?
The only marginally similar item that Canon has is the ST-E2 transmitter. Unfortunately, this does not allow you to have an ETTL flash on camera should you so desire.
That said, for indoor use in a relatively reflective room, Canon's IR ETTL signal will let you control your off-camera flash units without a cable while providing a better AF-assist solution.
Dec 19, 2012 at 11:09 PM
