Archive 2012 · 6D either discharged or died, with power save ON
ISO1600
p.1 #1 · p.1 #1 · 6D either discharged or died, with power save ON
My only battery is charging right now, so I don't know for sure, but-
Last night i left my 6D on, on the coffee table.
This morning i grabbed it on the way out the door. Went to take a shot, and nothing. Flipped power switch back and forth, still nothing. Ran inside, pulled the battery and tossed it in the charger. Charger blinked a few times, then stopped.
Threw battery back in camera. A few blinks from the card LED. Power switch. Nothing.
Now I'm at work, battery seems to be properly charging. We'll see in a bit.
I have power save set at 1min(default, right?). I've never had a Canon or Nikon drain the battery overnight with power save turned on.
This is a bit of a shocker to me, honestly.
Before anyone asks- yes this is official Canon battery and charger.
Dec 13, 2012 at 01:34 PM
ciprian.trofin
p.1 #2 · p.1 #2 · 6D either discharged or died, with power save ON
Have you left GPS / WiFi on ?
Dec 13, 2012 at 01:42 PM
Guari
p.1 #3 · p.1 #3 · 6D either discharged or died, with power save ON
you'll have your answer in a bit, once the battery charges
all the best with it
Dec 13, 2012 at 01:43 PM
ISO1600
p.1 #4 · p.1 #4 · 6D either discharged or died, with power save ON
GPS/WiFi were off, camera was off (via power save).
I only turn GPS/WiFi on when using them. Until now, the 6D's battery life had been thoroughly impressing me.
Dec 13, 2012 at 01:45 PM
Ralph Conway
p.1 #5 · p.1 #5 · 6D either discharged or died, with power save ON
Let us know who it goes on/turns out, please.
Ralph
Dec 13, 2012 at 01:58 PM
ISO1600
p.1 #6 · p.1 #6 · 6D either discharged or died, with power save ON
OK-
False alarm, somehow the battery died.
Question:
I have 1min Power Save turned on.
Below that is a setting for "LCD off/on btn"- default setting is "remains on". I'm not completely sure what this means.
Dec 13, 2012 at 04:25 PM
ben egbert
p.1 #7 · p.1 #7 · 6D either discharged or died, with power save ON
Is the 6D battery chipped so that other batteries do not work? If so, perhaps the internal electronics died.
Dec 13, 2012 at 05:12 PM
Gochugogi
p.1 #8 · p.1 #8 · 6D either discharged or died, with power save ON
I never turn off my 5D2/7D and the batteries are good for many weeks--even months--as battery drain nominal as long as no buttons are being pressed. On the other hand, the 6D has GPS and Wi-Fi so those functions increase battery drain if left enabled.
Dec 13, 2012 at 06:07 PM
dhphoto
p.1 #9 · p.1 #9 · 6D either discharged or died, with power save ON
FWIW my 5D3 loses about 6% overnight when left on but in 'sleep' mode, I assume it's a trickle it uses to wake the camera fast.
Dec 13, 2012 at 06:15 PM
ciprian.trofin
p.1 #10 · p.1 #10 · 6D either discharged or died, with power save ON
Wow. 6% is HUGE. 3 weeks in sleep mode and the battery is gone ?
My 400D and it's 5 year old batteries do sooooo much better
Dec 13, 2012 at 06:24 PM
ISO1600
p.1 #11 · p.1 #11 · 6D either discharged or died, with power save ON
My camera was at over 90% last night when left on the table.
GPS and WiFi were both OFF.
I don't know how it could have drained overnight, but it was 100% dead. D E D, DEAD.
Dec 13, 2012 at 06:27 PM
eosfun
p.1 #12 · p.1 #12 · 6D either discharged or died, with power save ON
Are you sure GPS and WiFi were off? Anyway, all new 6D users should look closely to the communication settings of the 6D. We are all used to battery lifes for our EOS-es until eternity, but this is not true for the 6D. As already said above, GPS and WiFi are real powerhungry. When these are on without further attention the batteries will drain rapidly. We have some experience when demoing the 6D in the camerastore already. Consumption is much more like smartphones and compacts with communication features. The camera is imo a great piece of EOSfun, but this is one of it's downsides in comparison to former models.
Dec 13, 2012 at 06:44 PM
Ralph Conway
p.1 #13 · p.1 #13 · 6D either discharged or died, with power save ON
@ ISO 1600:
But now it is recharged and camera works?
Let it on and watch if it happenes again, please.
@ eosfun:
Any problems when GPS/WIFI is off, too?
Ralph
Dec 13, 2012 at 06:45 PM
Yohan Pamudji
p.1 #14 · p.1 #14 · 6D either discharged or died, with power save ON
Maybe you put it in a bag and had one of the buttons accidentally pressed by something in the bag?
Dec 13, 2012 at 07:10 PM
ISO1600
p.1 #15 · p.1 #15 · 6D either discharged or died, with power save ON
it was sitting out, no bag/case, on table.
GPS and WIFI were both off, to the fullest extent. Drained full battery overnight, somehow.
Now everything seems fantastic!
Dec 13, 2012 at 08:18 PM
Ian.Dobinson
p.1 #16 · p.1 #16 · 6D either discharged or died, with power save ON
What lens do you have mounted?
It's happened in the past that certain lenses have drained batteries while the camera was off/in sleep mode.
Seem to remember firmware updates were needed to sort
Dec 13, 2012 at 09:54 PM
Access
p.1 #17 · p.1 #17 · 6D either discharged or died, with power save ON
Maybe this is obvious but have you asked around to see if your spouse/boyfriend/girlfriend/family member/son/daughter/pet/etc. happened to use it? That could explain the battery being empty.
Dec 13, 2012 at 10:46 PM
eosfun
p.1 #18 · p.1 #18 · 6D either discharged or died, with power save ON
Ralph Conway wrote:
@ eosfun:
Ralph
Ralph, not really problems, no. GPS and WiFi are obviously taking their share of the battery. In my opinion completely normal. I am just pointing this out to set expectations straight. As I said, most Canon D-SLR photographers are used to thousands of shots from their cameras, but the new 6D needs more charges if the GPS and WiFi communication modules are used intensively. Just something to take into account. The features are really great EOSfun (especially the WiFi and EOS-remote) but they take their share of battery power. TANSTAAFL.
Dec 13, 2012 at 10:57 PM
EB-1
p.1 #19 · p.1 #19 · 6D either discharged or died, with power save ON
So there is no option for the GPS and WiFi to time out after some minutes? It is rather lame that it is necessary to turn the power switch off like on my 1972 camera.
Dec 14, 2012 at 02:31 AM
ISO1600
p.1 #20 · p.1 #20 · 6D either discharged or died, with power save ON
The GPS and WIFI can be turned completely OFF in the menus. That is how they were that night.
The lens mounted was the 40/2.8 STM.
My wife and 8mo old son did not mess with it.
There was a SD card in the camera.
It was not raining outside.
Power save set at 1 min.
LAST night, i left the GPS on, but turned the camera off. I at least think i turned it off. This morning, it was full charge still.
Lesson from this story? As of yet, I don't completely trust the battery and/or camera, so i need to get another LPE6.
Until we figure out what could have caused it, I'll make sure and keep a very careful eye on the power.
Dec 14, 2012 at 01:41 PM
