What are the criteria?
A technical image
ben egbert
p.1 #1 · A technical image
I always wanted to try one of these, so when I was at Zion, I saw this opportunity. This is what I consider a technically challenging shot of no particular artistic merit.
  Canon EOS-1Ds Mark III    42 mm    f/22.0    1/100 sec    100 ISO    -0.7 EV
Dec 10, 2012 at 10:46 PM
sbeme
p.1 #2 · A technical image
Ben,
Not sure what kind of input you are looking for.
Technical?
Scott
Dec 10, 2012 at 10:55 PM
ben egbert
p.1 #3 · A technical image
Not sure what input is required for this. Maybe how to do it? How to process it? Why did I even take it? Why did I post it? The last is because of two reason, the forum is slow and I am out of stuff to post.
Dec 10, 2012 at 11:12 PM
AuntiPode
p.1 #4 · A technical image
"... one of these."
Shots with the sun?
Looks a bit dull in the leaves. Perhaps a bit of crop, a mid-tone bump, a smidgeon of sharpening, bumping the saturation for yellow and red to make the leaves pop, a bit of a crop, and some noise reduction:
Dec 10, 2012 at 11:27 PM
ben egbert
p.1 #5 · A technical image
Thanks Karen, that what I was looking for.
Dec 11, 2012 at 12:48 AM
RustyBug
p.1 #6 · A technical image
With the sun backlight, and the open sky being behind the leaves as well ... much of the lighting on the leaves is going to be diffuse (viewed from camera side), or translucent.
Diffuse lighting by nature is low contrast ... hence Karen's "bumps" to bring it up a notch. I'm not seeing much CA (at this size), what lens did you use?
Also, I'm a bit surprised by the exposure @ Sunny 22, which would suggest an underexposure from the usual Sunny 16. But, then again, with as many blown red channels as I had during my trip ... the light really must be stronger there.
Edited on Dec 11, 2012 at 12:58 PM · View previous versions
Dec 11, 2012 at 12:53 PM
_Rob_S_
p.1 #7 · A technical image
Interesting that the tree trunks are exposed as well as they are given the backlight. Was the ground/surface below very light in color to reflect light onto the trunks? I presume this was a single shot exposure?
Rob
Dec 11, 2012 at 12:57 PM
RustyBug
p.1 #8 · A technical image
Good point Rob.
ben egbert
p.1 #9 · A technical image
This is the new 24-70 f2.8 mk2 which is a pretty good lens for flare. I stopped down to get the star burst effect. It is also very good at CA.
Dec 11, 2012 at 03:54 PM
ben egbert
p.1 #10 · A technical image
RustyBug wrote:
Good point Rob.
CS6 is really good at bringing up shadows. The SOOC may answer some questions.
Dec 11, 2012 at 04:00 PM
RustyBug
p.1 #11 · A technical image
Gotcha ... that helps.
Dec 11, 2012 at 04:01 PM
ben egbert
p.1 #12 · A technical image
And here is one I tried to do with Karen's version in mind. I hate f22, at least 50 dust bunnies, but I sent the camera in last week and now it probably only has 20 at f22.
revised
Dec 11, 2012 at 04:26 PM
Mister Bean
p.1 #13 · A technical image
I wanted more glow in the leaves. It's starting to get a little crunchy here. But with the original it probably wouldn't be as bad.
Dec 11, 2012 at 06:05 PM
ben egbert
p.1 #14 · A technical image
Hi, was there before I worked on the black point.
Dec 11, 2012 at 07:31 PM
AuntiPode
p.1 #15 · A technical image
Forgot to mention I applied a noise reduction before sharpening to limit "The Crunchies".
Dec 11, 2012 at 09:22 PM
ben egbert
p.1 #16 · A technical image
Yep, I normally sharpen in ACR but when I need NR I turn it off and sharpen later. I had the advantage of working with the raw.
Dec 11, 2012 at 09:50 PM
Mister Bean
p.1 #17 · A technical image
This is more like what I was going for originally.
Dec 11, 2012 at 09:52 PM
ben egbert
p.1 #18 · A technical image
well you really pulled it up from the original. I can't figure out how to feel about this image.
Dec 11, 2012 at 10:03 PM
RustyBug
p.1 #19 · A technical image
Just feel what you feel ...
Dec 11, 2012 at 10:13 PM
ben egbert
p.1 #20 · A technical image
I feel a non keeper
Dec 11, 2012 at 10:36 PM
