D800 WON'T Lock up Mirror for Cleaning
uintaangler
p.1 #1 · D800 WON'T Lock up Mirror for Cleaning
Need a little HELP with something I'm hoping isn't a glitch
Tried to blow off the sensor on my D800 for the first time and the Menu Item " Lock Mirror Up for Cleaning " is greyed-out
The battery is charged to 100%
Any thoughts on what might be causing the problem?
Thanks,
Bob
Dec 10, 2012 at 02:26 PM
Zichar
p.1 #2 · D800 WON'T Lock up Mirror for Cleaning
I don't suppose you've got a grip on?
Sometimes it doesn't quite 'read' your battery state, take it out and replace then check again?
Or take it out, place it in charger again, recharge then back into camera and check again?
Dec 10, 2012 at 02:32 PM
uintaangler
p.1 #3 · D800 WON'T Lock up Mirror for Cleaning
I don't have a grip on the D800
Dec 10, 2012 at 02:33 PM
Guari
p.1 #4 · D800 WON'T Lock up Mirror for Cleaning
Thanks,
Bob
are you trying to raise the mirror with a lens attached?
Dec 10, 2012 at 02:39 PM
uintaangler
p.1 #5 · D800 WON'T Lock up Mirror for Cleaning
Of course not - how would I get to the sensor with a lens attached
Dec 10, 2012 at 02:40 PM
ckcarr
p.1 #6 · D800 WON'T Lock up Mirror for Cleaning
That doesn't matter.
It's got to be a power issue. Is the battery saying 100% in camera, or does the light stop blinking in the external charger?
Anything else grayed out on the menu that shouldn't be?
Dec 10, 2012 at 02:43 PM
uintaangler
p.1 #7 · D800 WON'T Lock up Mirror for Cleaning
Craig, it shows the battery full in the small top screen
Dec 10, 2012 at 02:44 PM
ckcarr
p.1 #8 · D800 WON'T Lock up Mirror for Cleaning
Try putting back in the charger for a bit. Not sure how reliable the in camera meter is.
Dec 10, 2012 at 02:46 PM
Matt OHarver
p.1 #9 · D800 WON'T Lock up Mirror for Cleaning
Make sure you have the network settings to off?
I know my D4 won't go into manual clean mode with that set on the menu is greyed out.
Matt
Dec 10, 2012 at 02:48 PM
ckcarr
p.1 #10 · D800 WON'T Lock up Mirror for Cleaning
What does it say the charge level is under the "SETUP MENU" (Battery info)...
Just playing with mine and a couple batteries, it will still lock up when it says 95% (not that I would clean the sensor at that level).
Dec 10, 2012 at 02:52 PM
uintaangler
p.1 #11 · D800 WON'T Lock up Mirror for Cleaning
Craig, the battery is currently back in the charger based on your previous suggestion
Stay tuned
Thanks,
Bob
Dec 10, 2012 at 02:54 PM
jacksonholer
p.1 #12 · D800 WON'T Lock up Mirror for Cleaning
Do you have your shutter button programmed to record movies in movie mode? If so, set it back to take pictures in custom settings and see if that works. Custom setting g4 should be set to 'Take Pictures'
No idea why it should matter but it does. Hopefully Nikon will fix it in the next update...
Dec 10, 2012 at 03:04 PM
uintaangler
p.1 #13 · D800 WON'T Lock up Mirror for Cleaning
Thanks jacksonholer that did the trick, but how freaking weird is that
Thanks to all for your responses
Bob
Dec 10, 2012 at 03:19 PM
parsons
p.1 #14 · D800 WON'T Lock up Mirror for Cleaning
boys and toys
Dec 10, 2012 at 07:40 PM
