Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skat...
shaolin95
p.1 #1 · Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skating on the cheap?
I know my SEl55210 is too slow (sony nex-6) so I was thinking that maybe that lens would be the cheapest way for me to get some decent shots at local hockey games and figure skating events.
I am trying the SEL55210 this Saturday anyway but I expect a tough day
Dec 07, 2012 at 11:29 PM
ssnap
p.1 #2 · Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skating on the cheap?
I had the 180mm 2.8 (not the D version) and it was a fantastic lens, but not for sports. The AF was too slow, but it was wonderful for portraits. I've heard that the 180mm f2.8D has quicker AF but I can't see it being ideal. Since it sounds like you are throwing this on an NEX-5 this may not matter too much. I can't imagine MF for hockey or figure skating. I do remember that part of the reason my 180 was so slow was because it took a lot of turning to go from minimum to infinity. I imagine that would be painful for MF scenarios.
Dec 08, 2012 at 02:14 AM
freaklikeme
p.1 #3 · Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skating on the cheap?
I don't think it's going to AF on his NEX, anyway, ssnap.
Depending on where you're shooting from, the 180 would be good. However, I think you're setting yourself up for some frustration shooting that long a tele. Are you not going to be able to shoot games from the glass? If you can, I'd go for a fast 50ish. The Rokkor 58/1.2 would be a good choice, since it's sharper at 1.2 then most 50/1.4s are wide open, but you have to be willing to MF your way through a hockey game, which is not a simple task. You might want to consider the 50/1.8, which is fairly snappy AF-wise and is stabilized, which could help with some cool tracking shots. But either of those will result in a great focal length for capturing action in front of the net from anywhere in the zone along the boards. End-to-end, I wouldn't look for something much longer than 135. It's easier to hand-hold, faster to focus, greater depth at f/2.8 and you'll run less chance of losing sight of the game. It's better to have to crop a little than not have enough space in your frame. Good MF 135's are fairly easy to find and typically pretty cheap. I'd go with Minolta or the E55 Leica R (prices may have gone up to silly levels on the Leica, but it was one of the good bargains in the line at one time). They tend to play better with the crappy ice arena lighting than the MF Nikons.
Just my two cents. As for figure skating... well, good luck with that.
Dec 08, 2012 at 08:03 AM
briantho
p.1 #4 · Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skating on the cheap?
A 50ish for a hockey game?
I'd bring my FD 300 f2.8 + maybe the 1.4x tele converter, and I'm sure I'd get hundereds of unusable photos, and about 10 great shots. That would be my expectation.
That's assuming the lens would be allowed inside the arena.
My .02
Dec 08, 2012 at 11:08 AM
shaolin95
p.1 #5 · Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skating on the cheap?
I am guessing today based on what range I end up using most would be a good indication of what I will need. I will not be near the boards for this event so I will need my zoom for sure.
Dec 08, 2012 at 04:24 PM
ytwong
p.1 #6 · Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skating on the cheap?
I have shoot soccer with 180 2.8, but with a D700. MF was an issue, but not impossible.. but a good viewfinder is really important. I can't imagine using NEX-6 with MF 180 2.8 for sports (I do have a NEX-7 but never used that combo).
Dec 08, 2012 at 05:47 PM
mawz
p.1 #7 · Is Nikkor 180mm 2.8 by best choice for Hockey/Figure Skating on the cheap?
I've shot sports with an EVF. With the G1 it was an exercise in frustration, but the NEX-7 does much better due to much improved lag times (and peaking).
Frankly I rate the NEX-7 EVF over the D700 OVF. But only by a small margin.
Dec 09, 2012 at 04:57 AM
